Rear Camber Kit / Tires Q
Old May 28, 2003
jskull21's Avatar
jskull21 is an unknown quantity at this point
I need a rear camber kit since I dropped my ride, I have 17's w/ 215/45 Pirellis.
I got them because I've got a lengthy commute. Problem is the tires are too wide for the camber kit, as far as I've heard. If this is true, does anyone have a suggestion for a good tire for commuting (which I only have to do for 6 more months), after which I can put on a better performance tire. Thanks in advance!
Also, from searching previous threads, its seems the SPC rear camber kit is the way to go, what do ya think?
Old May 28, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
Well I have the eibach camber kit, I believe its the same as the SPC. Anyhow I had the same problem but I have 18's with 215/35 tires, and I couldn't have my car properly aligned without rubbing.
Maybe you could switch to a 205 tire if they fit on the rims which they should.
You could prob get a good price on the Kuhmo Ecsta(sp). I hear they are a good tire for the price.
Old May 29, 2003
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
yeah, i would also have to say 205/45/17 tires. heres some cheap but good ones i've found on tires.com
Kumho Ecsta Supra 712
Falken Ziex ZE-512
Yokohama Parada Spec-2
Old May 29, 2003
jskull21's Avatar
thanks, i was already gonna go w/ the Yokohama parada spec 2s so i'll probably just stick with those
Old May 29, 2003
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
what you need to do is get an air saw and cut the metal lip in the wheel well that is about an inch.
happy adjusting of the camber
Old May 29, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
my car lowered with h&r sports 1.3" i have 215/45/17 with camber kit, no rubbing
Old May 29, 2003
jskull21's Avatar
I've got the h&r 1.3 also, w/ 215/45 17s and I'm just going by what the guy at the shop said, what camber kit do you have?
Old May 29, 2003
spc, all camber kit are the same, dont need the expensive ones, other than ingalls and spc i dunno which one is out for our cars, and i havent bring my car for alignment yet, just installed the camber kit 2 days ago but one side LOOK like 0 degree camber (tire is straight, no / \) and still no rubbing so its all good
Old May 29, 2003
jskull21's Avatar
thanks, right now mine are definetly / \, but the tires have held up pretty good, just a lil bit of spotting, but just looking at them its obvious, i'll go back to the guy and tell him what's up!
Makeice3498
Jul 2, 2015 11:13 AM
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
ImmortalEX
Oct 31, 2001 10:00 PM
