Suggested tire pressure
Old May 27, 2003
Veegee's Avatar
Veegee is an unknown quantity at this point
Hi, I'm kinda new around here. To all those who know a lot about tires, I need help. I want to know what's the suggested air pressure of a 205/45 17 tire? I put 29psi. on all four on a hot day, but normally I'd pump in about 30/31 psi.
Thanks in advance
Old May 27, 2003
Zzyzx's Avatar
Autocross Junky
I run my 205/40ZR17's at 32 on the nose and 30 rear, the higher pressure up front helps reduce tire rollover as I tend to take corners a little fast.
Old May 27, 2003
Voiceofid's Avatar
End Bringer
the tire usually have the recommended pressure written on it, i keep mine on 40
Old May 27, 2003
Veegee's Avatar
So I guess I'm ok at 31...I'll put 31 on the front tires and 30 on the rear ones...
The only thing that says something about tire pressure on my sidewall is the maximum amount, which is 40 psi.
Thanks guys..
Old May 27, 2003
Zzyzx's Avatar
Autocross Junky
The pressure listed on the tire is not the Recomended tire pressure, it is the max pressure that the tire is rated for.
Old May 27, 2003
Voiceofid's Avatar
End Bringer
maybe that's why my ride is so.. stiff..and so.. bald.. thanks guys
Old May 27, 2003
Veegee's Avatar
Can't find any resources on the internet on the proper inflation of my tyres ...hope you guys can point me to a site where there's any info about it....
Old May 27, 2003
Zzyzx's Avatar
Autocross Junky
Look in your door frame, the recomended tire pressure is listed there.
Tire pressure is based on the weight of the car. I believe that Honda recomends 30\30 I run a little more up front, as I love corners. When I use to autocross my street tires, I ran 45 on the front and 30 on the rear. not something I would recomend ever using on the street.
Check Here for more information.
Old May 27, 2003
Veegee's Avatar
but the sticker on the doorframe is for inflation of stock tyres right? I'll keep it at 31. Thanks!
Old May 27, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
If the door frame says 30 for a 15" tire, you can usually add 2-3 lbs for each size you go up... so for a 17, run 34-36 psi... I keep mine around 36 or 37 cuz if I make them too soft they start to follow the grooves in the road.
Old May 27, 2003
Veegee's Avatar
Duly noted Boilermaker! Thanks so much!
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jordan1794
Jun 8, 2015 04:03 AM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
artychris
Oct 24, 2001 10:14 AM
