18"rims
18"rims
Im am going to get rims soon (18s). And i was wondering if i should invest in a camber kit and struts first. Right now all i have is lowering springs, but im worried about rubbing and and if the camber will mess up my tires on the 18s.
Well, the stock struts aren't going to effect the rubbing very much.... how far the car is lowered, the offset on the wheels, the tire size and whether the camber is corrected or not will determine if it rubs or not. If it's a really close fit and it comes down to the struts... the only difference I can see it making is the extra bounce from the stock struts versus stiffer aftermarket ones. But as far as fitment, the struts have nothing to do with it. They'll only come into play if the suspension travels too far.
Originally posted by VNlilMAN
how do you know? you dont even know what size tires he's using
I bet he is going to put 215-35-18, 215-40-18,225-35-18, 225-40-18 one of those i bet he will put, and if he does i know he is not going to rub at all with the 2" drop !!!!!!!!!!!!!
The Standard One
225-40-18 doesnt rub with a 2" drop? are you sure? cause i have 215-40-18s with 1.75" and only have 1 finger gap... if it doesnt damn i should have gone with 225-35-18...
oh and sorry i forgot to say "you dont even know how much he's lowering the car either..
Balkos
Sep 11, 2015 11:39 PM
