question about clearcoat
I sure wish my car was newer
I've got a set of Racing Hart rims and on one, there is a small bad spot in the clear coat. It's no bigger than the eraser on a pencil, and it's a manufacture defect, you can easily tell it hasn't been curbed or anything. My question is, can I just buy clear coat, put it on, smooth it out, and call it a day, or should I do something else?
Autocross Junky
Ushually to fix clear coat, we would sand the affected area smooth, then sand the rest of the part (in this case the rest of the wheel) with out going through the clear coat, then spray the whole thing with clear. That way you get a nice top coat of clear. If you were to just spray the affected area, you would most likely still be able to see the damaged clear. Good luck with that.
CivicEnvy2001 - I'll check, but I believe they're past warranty. Also, what kind of rims/ defects did you have?
slystad810 - They're Racing Hart CR Evos, 17x7.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
