is my caliper screwed up?
Old Feb 20, 2003
Kadenx's Avatar
Yesterday, I replaced my front pads for inspection and noticed that on both sides, the lower caliper bolt isnt really engaged or disengaged with the threads on the caliper housing. The top bolt, however, came right out without any problems. I got the pads replaced fine because i just rotated the caliper on the bottom bolt to access the pads and piston. But what if I want to or need to remove my caliper? Is there a special honda trick??
Old Feb 20, 2003
solar's Avatar
solar is an unknown quantity at this point
The bolt should come out, and there are no specail tools or secerts for this, it should just come out. Its possible that the bolt was loose but just stuck in the rubber dust boot that surrounds the bolt. I hope it tightened back up, because if it didn't its probably still loose, and thats a bad thing. Or its possible its just stripped out, is this the first time you replaced the pads? Maybe it was stripped out in the factory. I'd make sure that bolt is tight ASAP.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Junquito89
Sep 27, 2015 10:22 PM
redcloud
Sep 7, 2015 01:45 PM
