Tire Balance??
Old Jan 5, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
Tire Balance??
When is the recommended time to balance our tires? it doesn't say in the manual. is it the same time we rotate??
Old Jan 5, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Every 7,500-10,000 miles
edit: at the same time, you rotate the wheels
Old Jan 5, 2003
so pretty much every other oil change. thanks
Old Jan 7, 2003
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I find this hard to believe but when I talked to a guy that balanced my wheels he recommended balancing the tires every time you remove them from the car which can suck cause I take my wheels off a lot...
2Hottie
Old Jan 8, 2003
vtecharry's Avatar
vtecharry is an unknown quantity at this point
That's not true. Don't listen to him. Do it every other oil change or every 8-10k mi. I have 3 cars and I 'm always swapping wheel/tire combos, for summer, winter, for racing season, etc.
Always check your tires for uneven wear or any weird patterns. It could be it needs a wheel alignment if your wheels/tires go out of balance frequently.
Old Jan 9, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
man you only balance your wheel's when you change your tires, to prevent yor wheels from vibrating,doing it every oil change is just a waste of $$$
SidCivic
Oct 3, 2015 06:00 AM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
EngiNERD
Aug 12, 2015 09:20 AM
jedi
Aug 3, 2015 04:26 PM
