Will 98 GSR rear brakes fit civic? HELP
Old Dec 21, 2002
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have the whole set up for the rear off a 98 GSR : control arms, Calipers, Rotors, brackets, everything needed to do a swap.. Will this bolt up to our civics? or am I missing something? any one tried this? someone who knows what they are talking about please let me know.. Thanks
Old Dec 21, 2002
RedDragon333's Avatar
No they wont just bolt in there will be some modification to get it done. Your best bet would be to go with the 02 SI rear disc conversion or wait for AEM and WIllwood to come out with it
Old Dec 21, 2002
RallyEX's Avatar
RallyEX is an unknown quantity at this point
I don't see how it could be all THAT hard, you probably won't need the control arms, however everything else you'll need. I imagine removing the drum brakes would be the first step so you have a bare hub with 4 studs coming out of it... fit the rotor on there and see how it fits, if it fits you will have to go to a machinist and have them custom fabricate an adapter to the calipers/bracket...
Mind you, I've never done this on our civics, nor do I know how the setup is behind the drums on honda's, but if you can squeeze the caliper on there after removing the drum brakes, and there seems to be enough room for everything, I'd give it a shot... who knows, it just might work... but it's hard to say.
Old Dec 21, 2002
Quote
[hr]Originally posted by: RallyEX
Mind you, I've never done this on our civics, nor do I know how the setup is behind the drums on honda's, but if you can squeeze the caliper on there after removing the drum brakes, and there seems to be enough room for everything, I'd give it a shot... who knows, it just might work... but it's hard to say.[hr]
its not as simple as removing the drum and bolting on a Rotor and "squeezing" a caliper on it its quite a bit more difficult ive seen the system behind the drum before, if it were as easy as you say it is why hasnt anyone "squeezed" on rear disc conversion yet, if was that easy i would already done it
Old Dec 21, 2002
Roadog's Avatar
Roadog is an unknown quantity at this point
Quote
[hr]Originally posted by: RedDragon333
No they wont just bolt in there will be some modification to get it done. Your best bet would be to go with the 02 SI rear disc conversion or wait for AEM and WIllwood to come out with it[hr]
totally correct! You also need to hook up parking brake cables to the rear calipers. The brake master cylinder is different also.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Poopies
Apr 20, 2017 11:36 PM
bsmiley
Apr 27, 2015 01:27 PM
mugenca
Apr 16, 2015 12:15 AM
aus10
Apr 13, 2015 09:26 PM
