*Impact wrench ok?*
*Impact wrench ok?*
Yeah, so I am having my springs put on tomorrow morning, and the shop will put my wheels on while they're at it...since I don't have a torque wrench yet (no cash for a few weeks) should I have them put them on? What if they use an Impact wrench, is that ok?? I heard most tire/wheel places use impact wrenches because they're faster. It won't screw up my wheels/lugs right?
The Standard One
ya ALOT of shops uses impact wrenches to put on wheels... yes it can be badd but usually its fine... i'm sure someone will disagree but hey, 90% of shops use it and i havnt really heard of anyone having problems so.. even if you did, take it back and bitch at them.
what kind or rims? steel? Alloy? Aluminum? If you spent some $$$ on nice rims, get those bad boys torqued properly, in MHO there is not excuse for a decent shop not to have the right tools for the job.
CivicLX620 is absolutly right they throw that on the end and it puts the lugs on and torques them instantly... but if they don't use that they should use a hand one, just ask them to torque them if you are worried and they should.
DIY King
If they know what they're doing they can set the torque with the impact wrench by varying the psi. Otherwise they can weaken and/or snap wheel studs. If they don't, then you will when taking the lug nuts off. Ours need to be tightened to 80 foot pounds. I tighten mine to 70 foot pounds since at 80 foot pounds there is over 12,000 pounds of force holding the wheel on to the hub. That's a lot of force! A screw is a wonderful invention. Thank you Archimedes!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Bruce2
Sep 21, 2015 08:01 PM
stank
Sep 16, 2015 07:40 AM
WaryDriver
Aug 8, 2015 05:08 PM
