Winter tires - width question
Old Oct 7, 2002
Pluto's Avatar
Pluto is an unknown quantity at this point
I'm gonna buy a set of Winter Tires for use on my Civic in Southern Ontario, Canada and need some help.
How can the tire width affect performance when it comes to winter tires? I have a choice of going with the stock size 185/65 on my 15" honda steel wheels or 195/60 which is very close in overall diameter.
We don't get a ton of real heavy snow here, just light wet snow and slush making the roads more slippery than anything. Not a ton of ice on the roads either.
Does a wider tire mean more or less traction? Does it differ between dry/wet/snowy/icey road conditions? I've heard in the past that a narrower tire will cut through snow better, not sure if that is true.
I'm considering the Michelin Artic Alpin and maybe some others if anyone has any suggestions for others I should be looking at.
Old Oct 8, 2002
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
The thinner the tire the better you will get through the snow. Wider tires are like pontoons in the snow.
Old Oct 8, 2002
Pluto's Avatar
Thanks for the reply DarkCivic, that's what I figured, I just wasn't sure.
On dry/wet roads though what is preferred? More tire on the road under those conditions = more traction right?
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
viper775
Dec 9, 2001 10:52 PM
technosilver
Nov 14, 2001 10:58 AM
