Brake pad install??
Old Oct 3, 2002
SilverStreakEX's Avatar
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX is an unknown quantity at this point
Brake pad install??
hey guys (and gals) i was just wondering, anybody install a set of front brake pads urselves? i just got a new set of brake pads and i need to install them. I dont like bringin my car to the shop (costs too much) so i wanted to install them myself. is it easy to do it yourself? can anybody give me a DIY? and before anybody flames, YES i did search, AND the DIY in that section is not working.
THANKS, SilverStreakEX (Nick)
Old Oct 3, 2002
Grey's Avatar
DIY King
****! The link to my DIY doesn't work. I found it though. Here it is: DIY: Rotor and Brake Pad Install
Old Oct 3, 2002
orso's Avatar
orso is an unknown quantity at this point
its easy. clean everything first. the diy is pretty straight forward. shouldn't have any probs.
Old Oct 5, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Grey,
What happens when the screw that holds the rotor on is painted over (my own stupid fault!)??? I tried to budge it, but it won't move...any suggestions??
2Hottie
Old Oct 5, 2002
duyaknow's Avatar
duyaknow is an unknown quantity at this point
I hope your using an impact gun. I think that's what ppl call them. You either have to buy or rent one. It's a screw driver that does a quarter turn everytime you smack it with a hammer. Your never suppose to use a regular screwdriver to remove that screw or you might strip it.
Old Oct 5, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: 2Hottie
Grey,
2Hottie[hr]
Well, if you can't unscrew it, then try paint thinner. Remove the paint from the screw. Then WD-40 it and try again. If that doesn't work, then try a longer wrench for more leverage. If that doesn't work, then you're going to need an impact wrench. It's an air tool, so it hooks up to a compressor. If you don't either one, then maybe go into a shop and have them unbolt it for you. I'm sure they'll only charge you $10.
Old Oct 6, 2002
hey grey, i tried following ur DIY in the brake pad install, and i cant get past step 6-7 i cant get those 2 big bolts loose (the ones that hold the caliper to the hub). any suggestions?[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Oct 6, 2002
Grey's Avatar
DIY King
I would turn the wheel all the way to one side to have better access to those bolts. Did you do that? Then remember that the directions will be reversed when you're unbolting it from the other side. You might actually be tightening it instead of loosening it. Make sure! That's about all I can say. Get a wrench with the longest arm possible. Maybe try extending it with a hollow pipe?
Old Oct 7, 2002
Pluto's Avatar
Pluto is an unknown quantity at this point
I used something my friend calls a 'johnson bar'... its like a long bar with a swivel bit at the end that fits into your socket bit... there is no wratcheting action but its good for just getting them cracked then you can use the regular wratchet wrench to take it off the rest.
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
