AEM rear rotor switch
Old Aug 28, 2002
cam's Avatar
cam
cam is an unknown quantity at this point
AEM rear disc switch
If i were to buy the rear drum to disc conversion kit from AEM, could i (after instalation) switch to a rotor from a different company (like wilwood for instance) or would i be stuck with rear aem rortors ?
Old Aug 28, 2002
slikor's Avatar
slikor is an unknown quantity at this point
you should be able to switch to any different rotor (as long as it was the same diamter and thickness, or else you'd have to make some adjustments. it would also have to be the same bolt pattern, etc) just fine...that is, if/when AEM has the rear-disc brake conversion kit out for our cars.
Old Aug 28, 2002
cam's Avatar
cam
ok sweet , just one more question would rotors ment for the front, be able to fit the back??
Old Aug 28, 2002
slikor's Avatar
well, it depends on how the rear disc conversion is done, how the disc mounts on the rear, etc. if you used the AEM brake upgrade kit when it comes out, you could ask them if the front and rear rotors would be interchangeable., then you could swap any rotor most likely with the AEM ones in the rear.
Old Aug 29, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
"ok sweet , just one more question would rotors ment for the front, be able to fit the back?? "
For brake balancing purposes, you'll want the rear rotors to be smaller than the front ones. You'll probably want the rears to be about 1" smaller than the fronts.
Old Aug 30, 2002
CapYoda's Avatar
Escaped Convict
from what I've read, in a car like ours... you will probably get better results swapping for better, bigger disc brake rotors on the front than do a rear drum to disc conversion...
most of the stopping comes from the front disc brake... and a new brake system will do wonders! (ie: 4 piston calipers and the likes)
I remember seeing this brand of brake kit from er.. willson or something. heh. seems like its pretty cheap on the wallet. (well, as cheap as 800 bucks can be?)
Old Sep 6, 2002
ashburn's Avatar
ashburn is an unknown quantity at this point
I didn't know that they where out how much are they
Old Sep 9, 2002
TWOK1CIVICON19S's Avatar
TWOK1CIVICON19S is an unknown quantity at this point
WILWOOD MAKE THEM. JEG'S PART NUMBER 950-140-6163-D 606.99
STAINLESS STEEL BRAUDED LINES 950-220-6420 69.99
94-01 CIVIC, IT WILL FIT OUR CAR
GOVERNMENT IS ANOTHER WAY TO SAY "BETTER THAN YOU"
Supramk3
Jun 11, 2015 11:13 AM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
masongap
May 26, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
