17" or 18" rims
Old Aug 22, 2002
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
17" or 18" rims
i have a 17" rims with 215 45 17 i like to go for 18" rims with 4o series tires
im still on the stock height and i got a sedan
1. what is the pros and cons
2. which is better
3. is this thing would fit w/out any problem or rubing
any help and info are greatly appreciated
Old Aug 22, 2002
Vizyun's Avatar
The Fallen Angel . . .
Vizyun is an unknown quantity at this point
Well, I can help a little.
1. Pros: 18's look better. That's about it.
Cons: Heavier, so may slow your ride down a little, and they cost more. Tires are more expensive, too. Also, easier to dent/scrape, but only slightly. Also, on stock springs, you'll raise about an inch or so.
2. I'd say 18's, if you get a light set. They look better, and you ride just as fast.
3. 18's with a 215/40/18 will fit no problem with no rub. In fact, you can drop with goldlines and still have no rub, if I'm not mistaken. And with a set of 18's, you'll want a drop, otherwise you'll look like a 4wheeler.
Advice: Try to find a set that will weigh the same or less than your steelies with tires. With a 40 series tire you'll have less chance of busting a rim, but I'd still drive carefully if I were you. I'd also invest in a camber kit if you don't already have one, and an upgraded set of shocks to match any lowering springs you decide on (I still recommend goldlines). Just be prepared to catch a few eyes!
Old Aug 22, 2002
thanks for the info
right now i have an axis se7en 17" and i like it
do i still need a camber kit if i stay at 17"
if im goin for 18 im looking for c2 or stay at axis se7en i think they are light
Old Aug 22, 2002
allenjanthony's Avatar
allenjanthony is an unknown quantity at this point
I have a quick question on the topic of wheel size. With the stock wheels and tires you have a given total diameter. If you keep your aftermarket wheels and tires in that same diameter, would it actually raise your car to make it look too high?
Old Aug 23, 2002
Vizyun's Avatar
Even if your car isn't any higher, it'll still LOOK higher because the bottom of the fender will be closer to the rim of the wheel.
As far as a camber kit, w/ a 17" rim I don't think it's an all out NECESSITY, but I'd recommend it to anyone with aftermarket wheels, just to save your tires. And I'd DEFINITELY recommend it to anyone w/ aftermarket wheels AND suspension. Just a precaution.
Old Aug 23, 2002
what brand do you recommend for camber kit SPC/INGALS
thanks for all the info vizyun
Old Aug 23, 2002
VNlilMAN's Avatar
The Standard One
i have 215-40-18s with neuspeed sports, 1 finger gap all around. no rub. dont have to worry too much about road hazards. but ya it raised my car .6"(cause its .6" bigger in diameter then stock) so now i have like a 1" drop rather then a 1.75" drop(ground clearance wise). it still looks pretty high so i'll probably get a kit. i'm kinda thinking i should have gone with 215-35-18 or maybe 225-35-18 cause the 40 series is a lil too thick for me. but then again atleast it saves my rims so..
Old Aug 23, 2002
thanks for all the info guys
Old Aug 24, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Yeah I am looking at 17" or 18" also but 18" is a little more expensive for replacing tires and so on. Also I hear the performance on the 17" is better than 18" but if you have the cash and good roads I say 18". Where I live 18" would attract attention and they would get jacked
Nick
Old Aug 24, 2002
VNlilMAN's Avatar
The Standard One
Quote
[hr]but if you have the cash and good roads I say 18". Where I live 18" would attract attention and they would get jacked[hr]
the roads here suck and i dont really live in a good neighborhood i still ride on 18s. why even fix up your car if you dont want to attract attention? isnt the whole point of making your car look to go make people go . i mean i know theres that risk of getting jacked but just prevent that from happening by getting 4 different wheel locks if you have to, a good alarm, etc... dont let thieves discourage you from making your car look good. i almost got jacked once already and only had them for a month but i also had many people complimenting my rims so its worth it to me. i just try to keep a good eye on it when i'm in badd neighborhoods.
Old Aug 24, 2002
what ever you do to your car if the theft want it they can get it they might take your car too
do you need an alignment if you have an aftermarket wheels. right now i have a 215 45 17 and axis se7en my car vibrate at 70-80 mph and it go to left [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
