Post unusual tire sizes...
Old Jun 15, 2002
Grey's Avatar
DIY King
Post unusual wheel sizes...
Please post unusual tire sizes. Something that's a larger diameter and width than stock (use the Tire Calc to make sure). Something that you're actually running on and something that gives you no problems at all. It can be lowered or not lowered, just mention which.
Old Jun 19, 2002
01EXtc's Avatar
01EXtc is an unknown quantity at this point
215.35.19 is pretty close, 225.30.19 is even closer, i dont think thats a real size though. with both sizes drivability is near zero, its off the trailer, on the trailer [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 19, 2002
mohawkboom's Avatar
195/70R14
No Problems.
Old Jun 23, 2002
Zolutar's Avatar
From: Utah, while roaming Montana, Idaho and Wyoming
Zolutar is an unknown quantity at this point
running 205/60/R15 on stock Alloys no problems whatsoever
Old Jun 24, 2002
TOOLOWCIVIC's Avatar
225-40-19 don't know if it will fit. My friend has 225-35-19 and still has a gap.
Old Jul 4, 2002
Kion's Avatar
Kion is an unknown quantity at this point
205/55/16's, ever so slightly bigger than stock diameter overall, no problems whatsoever (stock suspension)
Old Jul 10, 2002
pothole's Avatar
pothole is an unknown quantity at this point
225/40-18
Old Jul 24, 2002
VNlilMAN's Avatar
The Standard One
215-40-18 with neuspeed sports. 1 finger gap all around, no problems
Old Aug 2, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
215-50-16 is closet to stock that i can come up with, but only two or three tires made for that size
damn [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Aug 6, 2002
TWOK1CIVICON19S's Avatar
TWOK1CIVICON19S is an unknown quantity at this point
215-38/19, NO REAL PROB. A LITTLE RUB WHEN YOU TURN REAL TIGHT.
Old Aug 7, 2002
showoff's Avatar
showoff is an unknown quantity at this point
214/40/17 odometer off by thousands i'm switching to 45's asap.
Old Aug 13, 2002
ashburn's Avatar
ashburn is an unknown quantity at this point
I have 19 inch Racing Hart C3s on my 2k1 civic and the car is dropped about one inch. No problems so far it has been about one month now of regular driving.
You can't pimp your ride without 19's
Give me a holla I've got some 18X7.5 TMW with 215 40 R18 pirelli's for sale for $1000 three months old
Old Aug 23, 2002
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
215 45 17 no problem i need 2 drop my car and some $$$[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 3, 2002
4bangin's Avatar
195/50/16, no problems, 205/50/16, no problems, 215/40/17, no problems, never had it lowered yet but from all the other responses it doesnt seem like i will have a problem of rubbing with some lowering springs.
Old Sep 5, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
umm there was the progressive rsx with stock wheels 16X6.5 with 225X40 16tires and a 22mm rear sway & stock front sway .it did .96G on the skidsawsomeness
Old Sep 9, 2002
MrMondayNite's Avatar
MrMondayNite is an unknown quantity at this point
205/60/15 on stock suspension,No problems,love the Plus size.
Old Sep 19, 2002
Macker's Avatar
Macker is an unknown quantity at this point
215/50/17 with lowered suspension. Ride is a bit harsh but wouldnt change it a bit.
Old Sep 19, 2002
1chic2nv's Avatar
1chic2nv is an unknown quantity at this point
215-35-19 Pirelli P7000 Super Sport..Eibach Pro-Kit 1 inch
Old Sep 23, 2002
VtecPIMP218's Avatar
VtecPIMP218 is an unknown quantity at this point
i have 205-45-17's....and i have goldline springs and spc camber for my 01 sedan..will it rub w/ goldlines????? i dont know yet...i hope not...i will post pics soon...
Old Sep 23, 2002
VTECHPOWER's Avatar
VTECHPOWER is an unknown quantity at this point
Hey guys,
I just bought a pair of Yokahama Tires 245/45/17. They rub when I hit a bump going fast. What kind of damage may incurre while having this happen over time. I have this set of tires in the back. I have Yokahama Tires 215/45/17 in the front. The car seems to handle well b/c of the front tires. The ride is more comfortable b/c of the back tires. I gained a small bounce tough in the back as well as more roll due to the crossection of the 245/45/17's.
H man
Old Oct 13, 2002
Shawn02's Avatar
Shawn02 is an unknown quantity at this point
I have some kick a$$ Michelin 195/60/15 on stock ex steelies. Everything is great, and speedometer isn't off or anything....its only a slight difference in performance but was only 6 bucks more per tire.
Old Oct 16, 2002
AzNxTc's Avatar
AzNxTc is an unknown quantity at this point
215/45/17 toyo proxies. Too much negative camber on the rears, and my H&R springs are sagging on the rears so I'd estimate a 2.5" drop. They rub like hell on bumps and my fenders have little dents from my tires hitting the frame when i hit bumps. Any recommendations guys?
Old Oct 16, 2002
vincenzobar's Avatar
THE WOP
vincenzobar is an unknown quantity at this point
225 50 16 Yokohama A520's w/ 1.75" lower. had to dremel a quarter inch in on the rear fenders inside. And I rub turning hard and fast. I am changing my suspension to Skunk2 coilovers to remedy this problem. I have godline lowering springs now.
Old Nov 8, 2002
mohawkboom's Avatar
205/75R14 winter tires...Bigfoot civic!!!..no probs still stock suspension
Old Nov 15, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
I just saw my first pair(i was parked right next to it)
355/35/24
I was talking to the guy, his wheels add about a 1000 lbs to his ride(denali). I was sitting in my car and I could barely see over the tire.
I have 205/50/16 and they are fine.
Old Nov 18, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
currently running 205/50/15 Potenza's (speedo is way off), probably switching to either 215/45/15's (will send speedo even more off, almost 2" smaller in diameter than stock) or to 225/50/15's (with rolled rear fenders on H&R springs). Most likely to 225/50 because many many more tire options.
Old Nov 27, 2002
IH8SUVS's Avatar
IH8SUVS is an unknown quantity at this point
215/45R17 - very close in diameter, plus they aren't so thin that you have to steer around every pothole.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Dec 4, 2002
LadyInRed's Avatar
LadyInRed is an unknown quantity at this point
195/55/r15 with GC coilovers (yellow koni). drop to 2 fingers all round, no problems.
Old Dec 18, 2002
Edens's Avatar
Edens is an unknown quantity at this point
I was running 235/40ZR17 on my civic.(YES 235) with ground controls and a 2 inch drop. now before every one goes on saying that a 235/40 is much too tall. A 235/40 is actually a little bit shorter than the stock size on an EX. And the width is not impossible I had 17x7.5 wheels with a 45mm offset. hope this helps.
Old Dec 20, 2002
jaegs's Avatar
jaegs is an unknown quantity at this point
ive got 215/40/17. lowered a bunch on ground control coils, camber kit, yadda yadda. havent rubbed yet. dont know what that dude was talking about his odo being off thousands. the tire calc says my tire is the same height as the stock wheels
