Brake caliper question
Old Nov 1, 2020
Stevie Silliw's Avatar
NewToHondas
Stevie Silliw is an unknown quantity at this point
So I was just wondering if the calipers are different sizes between a DX and a LX? I have a set of 14 inch rims I want to put on but they won't fit on my front wheels so I'm trying to figure out what I can do. I MIGHT(can't remember) have EX calipers and brackets on my car but they are the same size as my old ones so it shouldn't matter. Does anyone think I can grind off at little of my brackets to make them fit? They don't hit the back of the caliper while rotating, they don't even slide into my studs which is why I think it's just the bracket hitting. I know it's not the safest so I don't need to hear that please, just curious.
Old Nov 1, 2020
FRSam's Avatar
Click Here
Re: Brake caliper question
Apologies if this is written anywhere and I’m just blind, but what gen is your civic?
Old Nov 1, 2020
Colin42's Avatar
Need to know year/generation
Old Nov 1, 2020
04 LX sedan, gents. OP's profile has the info filled out
edit: BUT, to answer your question, did a part number cross reference between an 04 LX sedan (what you have), 02 EX coupe (what I had), and 05 DX coupe (checked this for redundancy's sake), LX/EX have the same part numbers 45018-S5D-A00 and 45019-S5D-A00 for front right and left, respectively. 01-05 DX has a slightly different part number with 45018-S5D-L00 and 45019-S5D-L00 for front right and left, respectively. Couldn't tell you actual differences, though.
More importantly, regarding your clearance issues, what are the specs on those 14's you're trying to put on? Moreso the offset of said rims
Old Nov 2, 2020
BrotatoChip's Avatar
Super Moderator
DX does come with 14" wheels stock while EX/LX had 15". Maybe the EX/LX calipers are slightly larger and therefore the 14" wheel can't clear them. I've never paid attention to how much caliper clearance there was when I had the stock 15"s on my EX.
KaptainKendrick
Nov 24, 2019 01:18 AM
5hamers
Feb 20, 2017 11:06 AM
AzNmiKex215
Mar 23, 2004 12:05 AM
mclean987
Dec 5, 2003 12:28 PM
Lasher
Dec 1, 2002 01:00 PM
