Changing Caliper, Mounting Bolt Stuck, Can Change Caliper But Keep The Bracket (So I
Old Sep 17, 2017
hiac's Avatar
hiac is an unknown quantity at this point
change right front caliper for 02 honda civic.
caliper has two component: moving part, and the bracket (attached to hub).
the mounting bolt stuck and I can't take out the bracket. I wonder if I can use the bracket from old part, and only replace the moving part (which I have already taken out).
Many thanks!
Old Sep 17, 2017
Re: Changing Caliper, Mounting Bolt Stuck, Can Change Caliper But Keep The Bracket (S
Yes.
But if you have a new bracket in your hands, you may as well get the old one off the car now. Break off the stuck bolt and replace it if you have to.
Old Sep 17, 2017
hiac's Avatar
Originally Posted by ezone
Yes.
hi ezone,
thank you for your quick response, as always.
I will let it idle for 24 hours see if the chemical will penetrate in
Old Sep 18, 2017
mikey1's Avatar
the bracket attached to the hub rarely ever needs to be replaced,
why do you need to replace that?
Old Sep 18, 2017
In the future, if it has to be broken off to get it apart, he won't have a new bracket handy:
If he ever needs to take the rotors off, or replace a wheel bearing
If the slide pins seize up....... even if they aren't stuck now they may in the future
If the bracket is rusted enough to make the pads bind
