Hubcentric rings help!!!
Hi, i am in need of a set of Hub centric rings for my custom wheels,
i have a 2001 Civic EX Sedan with Motegi MR12 17x7 (4-lug universal)
but my prob is i dont know what size of hub centric rings i will need
Please help!!!!
Please help!!!!
Re: Hubcentric rings help!!!
well idk, its different depending on the wheels you got. i can tell you 1/2 of the size which is the stock hub but idk what your rim size is. call up the place you got your rims from, or ask treadepot.com thats where i got mine from. tell em what car you have and also what rims.
http://stores.ebay.com/Eurosport-Garage
buy ur rings from this guy, he is cheapest. at 9.95shipped, you cant go wrong. i just bought and received my pair 2 weeks ago for my slipstreams.
most aftermarket 4lug rims are 67mm OD (outer diameter)
just go outside, take off ur rims, and measure the diameter of the hole with a ruler that has millimeter... as i said, most are 67.
dont get metal. always get polycarbonate (i have both, and poly is far better)
nevermind, just found that they help eliminate corrosion and prevent metal on metal rubbing, how important are they? i've had my rims without them for 5 years now and no problems
supposedly its to balance the wheel to the hub, hence the name. so that your wheels dont vibrate at higher speeds. i did not notice a difference between ring and no ring. its mainly the quality of the rim that determines good balance.
not really. its goes in the center to have perfect balance and so ur rims wont have mad vibration while driving.
Green02civic
Jul 27, 2015 10:48 PM
estes53
Jul 20, 2015 10:43 PM
muttleytm
Jul 8, 2015 04:13 PM
