Brake problem
Old Jul 18, 2007
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Brake problem
So yeah I just did my brakes this past weekend. New rotors and pads. When I took the caliper off the car the ...
http://www.7thgencivic.com/old_attac...-brakeDIY2.jpg
The part circled in red... how it goes into the boot and theres grease in it..
Well one side does NOT move freeley it's stuck.
Is should be able to move back and forth correct?
My brakes still feel messed up so I have a 95% chance this is the problem..
Old Jul 18, 2007
roll_outz's Avatar
roll_outz is an unknown quantity at this point
Re: Brake problem
Bring it to ur mechanic Ur brake might Seize. or put some Anti seize lubricant.
Old Jul 18, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Brake problem
The pins can lock up. with the caliper apart, try to take it out, if it comes out, make sure its not scored up, there's a grease you can use to lube it up. If its truly siezed, you need a new caliper.
Old Jul 19, 2007
Maple50175's Avatar
Re: Brake problem
could that be why my brakes are still acting funny?
I can't even get it out. It moves a TINY bit..
ughh
Old Jul 19, 2007
burke420's Avatar
The World Is Yours!
Re: Brake problem
something loose!
conspiracy90
Jun 7, 2023 01:01 PM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
