tire question
Hey I recently came across a set of ADR sudoku8 rims 17" and since I needed new tires anyways this would be a good idea. Now I need to know what size tires to run and im a little confused cause I dont know what tire size im supposted to run..
ppl have told me for my 2001 Civic DX Sedan I should run eihter
205/40/17
215/40/17
Current Winter Tires: 185/70 R14
currently I have a set of XiCE on my tires right now for the winter so I dunno .. anyone help me shed some light? thx.
was thinking of picking up a set of FUZION HRi or FALKEN 512's anyone have any experience with these??
ADR Rim Specs:
p.c.d: 8 x 100/114.3
offset: 40
hub: 73.1
thanks guys
205/40/17
215/40/17
ADR Rim Specs:
offset: 40
hub: 73.1
thanks guys
Pwning Noobs 24/7
Re: tire question
the difference between these two
205/40/17
215/40/17
is just how wide the tire is, i use 215's on my car, there is no fitment problem or any rubbing, the wide tire provides more traction for the car when taking turns and etc...id recommend getting the 215 unless you are going to experience rubbing issues if you have a extreme drop
205/40/17
215/40/17
My cats breath smells like cat food.
Re: tire question
I run Toyo proxes 4 215/40/ZR17
The ride is just fine the grip and handeling are super!
But they will look a little small in the wheal well until you lower the ride.
Slowest 7thgen in the GTA
Re: tire question
I know I've hit the curb hard about three times in the last 14 years I have been driving.
Re: tire question
Honestly though I can't comment on the ride qulity of 40 series on a tuned suspension
When I do finaly drop my car I might Find that I will need to go with a 45 series
I'm also considering switching to 15's I will need to talk to some of the Auto-cross guys about that I believe the are the rim size of choice for that style of driving
Re: tire question
Ride comfort is a given.
What about, traction, handling, response, Lateral G-force.
Have these factors all improved since switching to the 15's?
Also could you post some pics?
Re: tire question
Ride comfort. My car's engine is 99.9% stock (the .1% is for the short ram intake) so traction, lateral g-force, etc don't really get tested on my car. But the ride of the car is so much smoother that I will never go back to a 17" tire. My car is not dropped and I don't have any pictures with the new rims, but here is a picture of a silver Civic from the discount tire site, with Enkei PKR's. Looks basically like my car...
Re: tire question
hrmm.. so after all this...
205/40 - rougher ride
205/45 - smoother ride...
but with consideration I have TEIN Stechs and Tokico Blue Struts on my car .. I think im going to opt out for the lower profile and go with the 205/40 .. is the 40/45 THAT much of a difference?
Re: tire question
A cheep no name tire will not be built with the same materials and structure as the top of the line tires like Bridgstone or Michillen.
The 40 series will look a hell of a lot nicer than 45's the ride is something all us tuners have to live with.
Go with the 40 series
Re: tire question
205/40/17
215/40/17
ADR Rim Specs:
offset: 40
hub: 73.1
thanks guys
205/40/17
215/40/17
ADR Rim Specs:
offset: 40
hub: 73.1
thanks guys
Re: tire question
The difference in size between a 205/40/17 and a 205/45/17 is shown below.
205/40/17
Width: 17in or 431.8mm
Diameter: 23.45in or 595.63mm
Sidwalll Height: 3.22in or 81.788mm
Revs per mile: 886.9
205/45/17
Diameter: 24.26in or 616.20mm
Sidwalll Height: 3.63in or 92.202mm
Revs per mile: 857.3
http://www.1010tires.com/TireSizeCal...?action=submit
205/40/17
205/45/17
I like my commute
Re: tire question
It is not just a question of 40 or 45 but also consider Brand.
-Falken 512 (they come in both 205/45/17 & 205/40/17) 40@$91/tire 45@$123
-Fuzion HRi (they only come in 205/40/17) @ $90/tire
so I guess now it just comes down to Falken or Fuzion.. and from what Ive read on the forums the Fuzion seems to be the best choice.. esp since they are made from 2 big companies
I like my commute
Re: tire question
Here's where I got my Falkens w/ a 205.45.17 .... http://www.edgeracing.com/tires/2054517/ 75 apeice!!
Re: tire question
Almost as good of a deal as this one in Dallas.
Brand new 205/40ZR17 NEXEN N3000 Tires - $38
BTW Nexen is made by Michelin.
http://dallas.craigslist.org/pts/299594972.html
Re: tire question
Nexen's are crap, and so are michelin's. Michelins are ok for regular driving, but not for summer tires. I'd go with the 512's over the fuzions. However the 512's might not last as long, but I think that's the sacrifice you have to make.
Don't cheap out with tires. You don't have to buy the most expensive ones, but don't go for the bargain barrel brands. Tires are one of the most important things on your car, if not the most important. They help out with acceleration, braking, and handling. Yes it can improve all of these depending on the tires you select.
Hey akz, go to tires23. I got my rims and tires there, those guys are good.
Hey don't post on TCC, those guys don't have that much knowledge on 7thgen civics. They know their 4th, 5th, and 6th gen civics, don't bother asking specific 7thgen questions there. They are ok with generic questions about about civics though.
thx anyways.. I think I just need to bite the bullet and buy new ones...
