205/60-15 Tires on OEM rim
Old Feb 7, 2007
K.Low's Avatar
K.Low is an unknown quantity at this point
I have a sweet deal on some 205/60-15 tires.
Will i encounter any problems mounting them on the stock rims ??
Thanks
Old Feb 7, 2007
TheSmuggler's Avatar
I believe 205 is the appropriate size for x7, and the stocks are x6 I believe. So the tires in question would work I'm sure, but would be beefy.
Old Feb 7, 2007
Da1lyDr1ver's Avatar
i think the stock rims are x6.5. but its probably different if you have steelies vs. alloys.
i would suggest you get 205/55/15. there will be no problems mounting that on your rims, but like previously said, it'll be a little beefy.
Old Feb 7, 2007
2k1_sedan's Avatar
2k1_sedan is an unknown quantity at this point
The stock steel rims are 15x6.
Old Feb 7, 2007
And 205's fit just right on my friends x7's, with the tire just touching over the lip. So they'll be think (wideness) on stock wheels
Old Feb 8, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
ive seen a member here with 205/60/15 on some alloys and it looked really beefy and thick, which looked ugly IMO. i would suggest to go with a 55 series.
what OEM rims do you have?
Old Feb 8, 2007
I'd be worried about the width more, since 205 is a typical x7 tire
Old Feb 9, 2007
^you're right, i think 195/60/15 would be more appropiate. cheaper than 55 series and available almost anywhere.
Old Feb 9, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
whatchu talking about..205/55/15 or 205/50/15 is good. it fits both x6-7. id rather have 205 rather then 195...think about it...if i had to look for tires...205/50/15. plain and simple..btw im riding on 15x6 si riimzzzzzzzzzzz
Old Feb 9, 2007
K.Low's Avatar
man i dunno i heard 205/50-15 is gonna **** my speedo.
Old Feb 10, 2007
205 is generally better than a 195 wide tire but the OP didnt give enough info in what he or she was looking for in a tire. i figured price as he said he can get that set for a sweet deal.
check out this tire calculator for speedo info, Tire size calculator
Old Feb 10, 2007
ragingSPAM's Avatar
I just burnt my tongue
ok 205/60/15 is gonna be way too big of a sidewall...205/55/15 have the same sidewall height of a 195/60/15...going from 195/60/15 to a 205/50/15 wont mess with your speedo much at all...mine hasnt been affected by more than 2-3 mph tops...all oem 15inch alloys from civics are 15x6 not 15x6.5 the 15 inch steelies are 15x6 also...like it was said earlier 205 sidewall tires can fit on 5.5-7.5 inch wheels...and the largest you can go on a 6 inch wheel is 225...trust me i sell and work with tires everyday so i know some stuff...not all but a lot
Old Feb 10, 2007
K.Low's Avatar
Thanks
Old Feb 10, 2007
I know it would fit, and since he's on OEM's I'd hardly say he's considering performance, and looking for as close to an oem fit as possible. In which case 205 is silly
Old Feb 10, 2007
K.Low's Avatar
205/50-15 Azenis on Oem why not ???
Old Feb 10, 2007
Because I like oem sized tires on oem wheels lol. They'll fit, and they'll buldge.
Old Feb 10, 2007
every database has 6.5 listed for the civic EX
Old Feb 13, 2007
thats a nice tire and size but hell of an change from a 60 series isnt it? if i wasnt worried about tire calculations, id go with an 205/55 series...its inbetween OEM spec and performance side. ive seen few integras and civics with 205/50/15 with not much of a drop with big wheel gaps. but if your looking something closer to the OEM specs, go with 195/60/15.
Old Feb 13, 2007
tougEMII's Avatar
u act like its the end of the world if they use this...fyi 205/50 or 205/55 is commonly used on 15x6. theres nothing wrong with it. the worst thing that can ever happen if u use a series like that on oem rims is sidewall flex..but if u get certain tires, it eliminates that
Old Feb 13, 2007
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
well heres my 2 cents on the 205 deal on stock 15' wheels
ive been running 205/50/15's on my STOCK STEELIES for about 9 months now and i love it..
im lowered with goldline lowering springs for the rsx and tokico struts for the 01 civic... and ive ran those tires for a while now..
i have no camber kit on the front or rear , got 2 alignments done after lowering it because the first place did my alignment and put the car on there with the wheel turn sideways and aligned it for that.. then the second place fixed it ..
but i run a Dayton Daytona HR 205/50/15 and i havent had any problems.. my speedo reads about 2-4 mph faster than im going once i get past 85 ... but before 85 its dead on...
whenever i get home ill update this thread with pics of the civic and show you..
i think it looks hot having that 205 back there from a back shot ... my car CANNOT drive over a speed bump without scraping but i love it that low ... but the stock 15's with 205's with work and IMO is hawt
but thats my 02... call me a ricer or whatever ..but a 205 is alot better than a 185 ... or a 195..
Old Feb 13, 2007
ragingSPAM's Avatar
i have 205/50/15 azenis on my oem wheels...i love the tires so much...so grippy...once i get my 17" advan RG-II or work emotions ill get either 225/45/17 or 235/40/17...most likley the 225 cuz they have reinforced sidewalls
Old Feb 13, 2007
tougEMII's Avatar
and u wont rub ? would u able to do a 16x7 with 225? and one more thing hows ur car man...and r u still going to thurs nights
Old Feb 14, 2007
Bad_Civc's Avatar
heres the pics of the 205's ...
its old pics of when i wrecked my car but its the only ones i can find showing the 205's
Enigma346
Lighting
Jul 12, 2015 08:24 PM
hayden55
Jul 8, 2015 11:38 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
hatch90
Jul 5, 2015 01:17 AM
