195/50/15????
Old Aug 21, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
195/50/15????
my stock tires on my EX are baldin..... i was wondering if it advisable to go 195/50/15 rather then 195/60/15???? can i get ur input.... my civic looks high wit the stock tires.... thought lowering the tire size might help... thankS!!
Old Aug 21, 2006
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
heres a 205/50/15 ...
but thats a 205 on the stock steelie.. i have no problems and it looks pretty bitchin from behind with that 205 ..
but you can run that 195 on the stock rim but it prolly wont make your car any lower..
by the way im lowered on tokico struts and goldline lowering springs.. the first pic is how i sit all the time on flat level pavement..
Old Aug 21, 2006
CuRiOuSfIsH's Avatar
Back From The Banned!
if youre on stock suspension, it will probably make your wheel gap larger. But you'll get shorter gearing but less gas milleage.
Old Aug 21, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
stay with the stock specifications of 195/60zr15 or 205/60zr15 thats what i ended up doing. and remember run your falken's well. Because if you treat them right, they'll do the same
Old Aug 22, 2006
djrabbi's Avatar
how come ur profile from first and second pics look different... the second one looks nicee
Old Aug 22, 2006
LiKEaFeRiO's Avatar
205/50 and 195/50 ARE NOT THE SAME SIZED TIRES.
The 50 is aspect ratio, not an actual measurement of the thickness of the sidewall.
That means 205/50 and 195/50 do not have the same sidewall size.
195/50/15 is too small in my opinion.
Looks wise, sure your car will be lower to the ground but you are also increasing wheel gap, which makes your car look like its even higher than stock.
Stick with the stock size or get a 205/55 if you can.
Old Aug 22, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
Yeah go with 205/55/15, it will look a lot better. A wider tire gives better traction.
Old Aug 22, 2006
djrabbi's Avatar
205/50/15 is good i think thanks GUYS!!
Old Aug 24, 2006
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
195/60R15, 205/55R15, Do it right the first time.
Old Aug 24, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
It might be good, but it is right.
Dont do it.
Stick with stok size
90civicbns
Mar 4, 2013 02:08 AM
sk8r
Mar 2, 2006 04:05 PM
sleeper2002
Jun 21, 2005 05:02 PM
hugo
May 15, 2005 10:25 PM
cheukkin
Dec 15, 2004 08:28 PM
