what tires are good??
Old May 21, 2006
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura aboutHwNpRyDe_CiViC has a spectacular aura about
hey guys need new tires.. i have falken zeix but i hate them. had them on for 2 thousand miles and 2 already total blow outs. side wall to thin.. hwat tires you think are good. i was thinkin maybe dunlop direzza?? help me out... i need prolly 205/40/17.. i want good ones some sport ones.. please help me i need em asap.. thanks..
Old May 21, 2006
kasimmmmm's Avatar
Toyo T1-R and T1-S are THE best tires i've used... they're expensive but worth it. Yokohama ES100s are #2 on my list. Most of the tires are equally sticky in dry, what sets them apart is how they perform in the wet, so look out for that.
Old May 21, 2006
ragingSPAM's Avatar
I just burnt my tongue
well seeing that u have 40 sidewall and hitting potholes is what causes them to blow out...i recommend falken azenis 215/40/17...the sidewall would be a little bigger helping
Old May 21, 2006
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
If Azenis you have 2 good choses, the RT 615's or the ST 115's. If you want best tires go for RA1's or Yokahama Advans.
Old May 21, 2006
blk04civiclx's Avatar
blk04civiclx is an unknown quantity at this point
i would assume the ziex arent so great because they are only 75 a peice.. yokahoma advans are good, they come with the new gs430. expensive though.
Old May 21, 2006
diskreet's Avatar
I have Toyo proxes 4s and they are amazing tires. They are awesome in the dry, with huge grip. In rain they are great. In snow they are amazingly good (drove 2 times on snow with them, once was over 2" on the ground).
The treadwear is ok on them, but good compared to other high performance tires.
All around they are good in any situation. Good tire, good price, great value.
Old May 21, 2006
what do you suggest 40 or 50?
Old May 21, 2006
EM2 Bluez's Avatar
40 is better then 50, if anything look at the tire dimension calculator thingy mah jigger
Old May 26, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
^its tough to say 40 series > 50 series tires. in this thread starters case, yes it does because he or she is blowing out tires left and right.
you definately dont want to run a 40 series tire if you want to avoid tire blowouts. for 17's, id personally go with 215/45/17 or 205/45/17 (if you can afford it, also less variety).
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
bo_red
Apr 23, 2015 10:09 PM
technosilver
Nov 14, 2001 10:58 AM
