a little help!
Old May 2, 2006
exturbo6's Avatar
a little help!
OK i just bought a set of supermesh rims from robear racing..the size is 16x7..what size tire would you get? im lowered 2 inchs..i dont rememeber what size i had on my car last year, plus different rims, but i know that i had 16x7 before and the tire would hit the inner wheel well when i would turn or hitting a bump, or just moving...and the outside of the tire was whereing away from the metal.
thanks!
Old May 2, 2006
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
205/45/16, 45 series for a little comfort, if you like rubber bands around your wheel then get 40 series. you have to either trim the inner rear fenders, or roll them with a baseball bat. also you need a camber kit for at least the rear, saves on premature tire wear.
Old May 2, 2006
exturbo6's Avatar
yeah i got a camber kit..ive had t fromt the last time i did my car.how would i roll my fenders with a baseball bat.
Old May 2, 2006
DDragon7's Avatar
Actually the right size is 205/50/16.
Old May 2, 2006
look inside the fender well which has a lip of about an inch. look at the sidewall of your tire where it could possibly rub the fender. now stick the bat between both, one side of the bat will rub against the tire, the other will rub against the lip of the fender. if you've never done this get with someone who has.
50 series tires are too thick in my opinion, looks stock.
Old May 2, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
That is correct/prefered tire size
Old May 3, 2006
exturbo6's Avatar
well i was thinking of buying 205/45/16. just to be a lil a more safer...i got my cuz's boyfriend getting me tires..he works for a tire place..looking at the new falken drift tire, and the new cooper drift tire.
Old May 3, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
Here is a tire size calculator. http://www.miata.net/garage/tirecalc.html
I used this calculator to first type in the OEM tire size, then typed in the size of the new tire that I was going to use. I wouldn't go with ANYTHING that's over 2 or 3 % different than stock, or your speedo will be WAY off. I'm using 19's and I'm only about 3 miles an hour off at around 70 MPH.
Old May 3, 2006
exturbo6's Avatar
idk even know what my stock tire size is.
