rims bending
Old Feb 11, 2006
nemar12345's Avatar
nemar12345 is an unknown quantity at this point
Question rims bending
If i were to get 18 in rims with 215-35-18 tires, how succeptable would they be to denting when on a rough road? Will the rim dent when going over a small pothole or a bug bump in the road. Im just wondering, because where i'm from, a few of the roads are not in the nicest of conditions. Thanks
Old Feb 11, 2006
RHCP0801's Avatar
it will have to be a huge crater for them to actually bend and you will have to be going really fast, i have never heard of rims bending but maybe someone has.
Old Feb 11, 2006
nemar12345's Avatar
i guess i dont really mean bend. just like small dents. But everything should be fine if i keep the tire pressure up right? thanks
Old Feb 11, 2006
RHCP0801's Avatar
if the tire pressure is kept just right they should be fine but if you hit a curb or something they might dent up, it really depends but it would be hard to dent them if they are quality rims, now scratches is a whole different story, those are easy to get if you hit a pothole at a bad angle or run against a curb
Old Feb 11, 2006
nemar12345's Avatar
ya, thats what i thought. Thanks for the help. I want to get some enkei rs6 rims. Im just waiting till the spring.
Old Feb 12, 2006
mugenman's Avatar
"mmmBAHHHH" - vtec y0
also it depends on what size tires....if ur goin with low profiles then u have more of a risk of things getting messed up. i had 205-40-17's and a potholl pinched the sidewall of my tire.
Old Feb 12, 2006
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
depends on if your going to drop or not also....if not, might as well go with the 215/40s, couldnt hurt. You can even still get a decent drop with those and still not rub.
Old Feb 12, 2006
nemar12345's Avatar
how much of a drop could i get with the 215/40/18's. Thanks
Old Feb 14, 2006
eziey's Avatar
eziey is an unknown quantity at this point
with 40's on 18's , not as much as you would like , youll scrubb the tires quicker than you would with 35's , as far as the bending , that mainlly happens on the outter lip , but you gotta have like a flat tire goin pretty fast and kill a huge pothole , or a pretty big difference in surface heights
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Balkos
Sep 11, 2015 11:39 PM
