Tire Stem leaking...
Old Jan 11, 2006
SinaloaCivic's Avatar
Ill punch you in the face before you visit Myspace
SinaloaCivic is an unknown quantity at this point
ok i have 18" Toyo Proxes FZ4 tires and i noticed one of them was very low on air, and as i was putting air in it from my compressor i noticed that it is leaking from that area, now i know that those can be replaced but what about on low profile tires?? is it the same on those or not? also is it true that if a tire has a hole in it, it is useless??? on a low pro that is.....any info or links would be appreciated
-PeTeY!! ::EM2::
Old Jan 11, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
just replace the valvestem core. Its replaceable on any rim. Walk into napa get the valvestem tool and some cores, should cost less than 5 bucks.
Just have air handy and jack the car up when you do it (the tire will fully deflate)
Old Jan 11, 2006
oh ok, thanks, im a real big noob when it comes to replacing stuff on tires so my dad said for me to take it to a shop that works on low profile tires and have them do it, he said hell pay for it...hes kinda worried about me.....umm is thier anything in particular for me to know when im talking to the tire guys thier?
Old Jan 11, 2006
Jap-Euro Fusion
it has nothing to do with the tire. its the valve stem. inside it there's a core thats the valve with the little plunger that opens and closes. it threads into the valve stem. on it is a couple of o-rings. they wear out from time to time. I go through these things like underwear.... there's a reason a 5 pack is 2 bucks.
Just jack the car up, stick the tool in, remove the old core, put the new one in, refill the tire.
Old Jan 11, 2006
hmmm ok sounds easy i think ill give it a try and ill update u
Old Jan 12, 2006
ok well i did it, and it worked out to be super easy and im glad i did it myself because it only cost me 8 bucks to do and the shop was charging 30 bucks but then i needed 2 new stems so yea thanks for the help
Old Jan 12, 2006
pon55's Avatar
"that" is what this board is all about, helping each other!
(rep the man!)
Old Jan 12, 2006
(rep the man!)
true, i just did, he deserves the rep lol
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
