wide wheels/tires, just double checking
Old Dec 15, 2005
kiwi133's Avatar
kiwi133 is an unknown quantity at this point
So as far as I can tell these will fit no prob, but I thought I would just throw it out for some feedback.
15"x7" Rota slipstreams +40mm offset
225 50 15" tires, falken ziex 512s specifically
04 ex coupe, rsx rear sway bar soon, not lowered never will be.
Thanks!
Old Dec 15, 2005
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
225 is pretty wide for a 7in wheel....but they shouldn't rub cause you're not lowered...i got 215 50s on my 17s right now, just cause i needed some tires...the rears rub pretty bad but it's all good up front so you should have plenty of room with 15in wheels
Old Dec 15, 2005
kiwi133's Avatar
the tire says its for 6-8" rim, and the listed specs were measured with it on a 7" rim. so I hope I can trust the numbers
Old Dec 15, 2005
kiwi133's Avatar
btw I won't be useing this set up for racing or auto-x. Just getting around and the occational hard turn.
Old Dec 15, 2005
Zzyzx's Avatar
Autocross Junky
225's are fine on a 7" wheel.
Old Dec 15, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
pfffft 7" rims. HA
Old Dec 15, 2005
kiwi133's Avatar
and how wide would your's be boiler?????
Old Dec 15, 2005
Jap-Euro Fusion
Old Dec 15, 2005
kiwi133's Avatar
mmmmmmm, wheeeeel. They even make meats to fit that!!!
Well, I feel completely safe with 7" now
(I assume those are 15"?)
Old Dec 15, 2005
Jap-Euro Fusion
16x8
Old Dec 23, 2005
EM2 Bluez's Avatar
EM2 Bluez is an unknown quantity at this point
I like your set up alot. I am going for some 17x7's with 215/45-17 not lowered with sway bars and upgraded suspension parts. Since you are going 15's though 215 should be the biggest
Old Dec 25, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
18 x 8 here slow but wide
Old Dec 25, 2005
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Thanks!
Nice setup! How much did everything cost you?
Old Jan 1, 2006
kiwi133's Avatar
Have not bought the wheels/tires yet, but I should be able to get it all for 700. got the swaybar for $60 on ebay, and that alone is awesome for the car. much nicer feel to turning now, like it doesn't have to try as hard.
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
