big brake kit behind 16's ??
Old Dec 11, 2005
ryangt's Avatar
ryangt is an unknown quantity at this point
i bought a aem big brake kit, but cant find a for sure answer as to what size wheels i need. I have 16's at the moment. Some sources say you need 16's and some say 17's.
does anyone have this kit behind 16's?
am i gonna have any problems or what?
lemme know guys
thanks for the
Old Dec 11, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
it fits behind SOME 16s. Its dependent on the offset, the thickness and the arch of the spokes whether or not it clears. 17's are a sure fire fit, which is why they say to use 17s. I've seen it done with 16s once, I kid you not there was NO clearance between the caliper and the rim.
Old Dec 11, 2005
ryangt's Avatar
im not too sure of the offset of these wheels, they are from bsr racing i beleive, ive never heard of those but they were on the car when i bought it so whateva. im not too sure if it will work, is there a way to measure or should i just install and check if it fits or not?
i have 17s as well but i need tires on those Badly so i cant put them on at the moment.
Old Dec 11, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
im using 16s on this kit. it fits perfectly they also recommend 17s for be tter cooling.. with my 16s it is a pretty tight fit.
Old Dec 11, 2005
ryangt's Avatar
im going to put the tires on those 17's but im deploying to iraq soon so i dont wanna invest in new rubber just to have it parked for 6-9 months, im buying a g35 when i get back anyways so the vic will turn into the commuter....... the commuter with a k20 and a jrsc kit
Old Dec 11, 2005
ryangt's Avatar
hey also how do you like the kit? im gonna be using the aem big brake kit, aem pads, and ss brake lines
Old Dec 12, 2005
im stock now! T.T
the kit is very nice, this is my second set, however, I am not going with this kit anymore, Im going to go 15s with drag radials so these brakes will not work.
I had no ss lines and still love these brakes. I used them once with the aem pads but the aem pads wore out soooo quick that i never used the aem pads again.
Old Dec 12, 2005
ryangt's Avatar
hmm maybe ill have to get some hawk pads or something
Old Dec 12, 2005
im stock now! T.T
dont get me wrong the aem pads were good just that for me, they ran out too quick..
Old Dec 12, 2005
ryangt's Avatar
how quickly? i dont do much stop and go, usually just freeway for commutes late night
Old Dec 13, 2005
ImportRacer2123's Avatar
K20 Member
will the AEM BBK fit Rota 16" C8?
Old Dec 13, 2005
ryangt's Avatar
dunno give it a shot
Old Dec 13, 2005
karlozc2003's Avatar
karlozc2003 should not be trusted
Hey Ryan why don't you give a try to pay me my money?
Old Dec 15, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
lol ^^^ i would like to know too =P
Old Dec 15, 2005
03EXD17's Avatar
03EXD17 is an unknown quantity at this point
I have 17x7 ADR spades and mt AEM big brake kit would'nt fit behind them so I had to get a set of spacers.
Old Dec 15, 2005
Jap-Euro Fusion
Here's 11.1" under a 16. Add another inch to that. if it does fit, you'll have no clearance.
Honestly I think the big rotor kit (because its not a big brake kit) is a complete waste of money. All it does is put a big heavy rotor in there, you don't gain any friction surface and it's $400 bucks every time you gotta replace the rotors.
Old Dec 15, 2005
ryangt's Avatar
i picked up the kit, plus pads and ss lines for 225, i think thats a good deal
Old Dec 17, 2005
im stock now! T.T
the rotors are bigger than stock, I have measured them. I havent seen one that havent fit in a 16" rim. Im using hfp rim right now and last set I was using aftermarket wheels that had a inner cap and it still fit. I think they are a great advantage over stock. they arent worth 400 u can get used ones for like a 100..
you shouldnt need to use ur 17s so dont waste money on buying new tires unless you have to. 16s will be fine
you will notice a dramatic improvement in the rain if you got abs, I know I did.
Old Dec 18, 2005
ryangt's Avatar
thanks man, hey where in cali are you?? im out in Riverside. Im gonna try those brake this weekend. I have to clean them up first, the guy i bought them off of painted them silver, they look dumb.
Hey Should i resurface these before i put them on? the pads and rotors look just fine, but i cant tell for sure.
Old Dec 18, 2005
blackdragon's Avatar
blackdragon will become famous soon enoughblackdragon will become famous soon enough
spacers would work on 16's but it depends on the spokes on the rim
Old Dec 18, 2005
ryangt's Avatar
im gonna try to put them on and ill post up for sure if they fit or not, as well as a diy
Old Dec 18, 2005
im stock now! T.T
dont resurface it if u dont have too. Everytime you resurface them they will lose the pedal feeling. I resurfaced mine once buts that for 20+k miles. After I resurfaced them I had to press the pedal harder..
only do it if uneed to, otherwise leave them alone, also they will become clean when the pads rub against them for the first time just give it some time. I should show u how they fit on my 16s been rid ing like that for a while now. They fit alright just the cooling isnt all that great.. since there isnt much clearance.
Old Dec 18, 2005
im stock now! T.T
dont need spacers for 16s with aem big brakes..
Old Dec 19, 2005
ryangt's Avatar
you have a pic you could email me ?
Rc2u4@aol.com if you have one
im attempting that install today
Old Dec 20, 2005
ryangt's Avatar
well the verdict is in ( drumroll please)
THEY FIT
just perfectly, have about a half inch clearance from the top of the caliper
Old Dec 21, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
THEY FIT
Can you post a pic to see how it looks?
Thanks
Old Dec 22, 2005
ryangt's Avatar
yeah ill put one up in the morning
anyone know how to put the pic in the post?
Old Dec 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
I've got 16" wheels on for snow wheels, and they clear my big brake kit i'll take pictures tonite if i remmeber
Old Dec 27, 2005
ryangt's Avatar
BEFORE
AFTER
Old Dec 27, 2005
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
damn that looks hot. hows the stopping distance?
