Members with 17's..Question
Old Sep 26, 2005
Tbag's Avatar
Tbag is an unknown quantity at this point
Simple question:
Has anyone bought 17's and had them perfect with no vibration in the steering wheel? I can't seem to get mine ballanced (rim and tire package) This will be the 3rd ballance job with sticky weights....still shaking at 60+ mph. Is this the nature of the beast? I see all these cars with OEM 17's with no problems....WTF?
Old Sep 26, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
i've had some issues, but it's been resolved......bring it to a good shop
Old Sep 26, 2005
TheSmuggler's Avatar
Werid I never had any problems
Old Sep 26, 2005
SLO REX's Avatar
250+ awhp Stage 2
Me either, but you might want to realign your front end.
Old Sep 26, 2005
Day_Tripper's Avatar
Owned By Slo Rex
I've never had issues...
Old Sep 26, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
I have had issues. One problem i had was a blown oem strut from lowering it. Also putting a strut bar on the front helped alot. Mine still does it but its only over the crappy roads and its very light. Btw the tire has some to do with it too.
Old Sep 26, 2005
prccivic's Avatar
alignment?......hub rings?....better shop?
Old Sep 26, 2005
Tbag's Avatar
Had the alignment check...good to go. I guess some tires can't be ballanced...BTW they are Hankook Ventus 205 45
Old Sep 26, 2005
Tbag's Avatar
Hub rings...got'm. All the shops tell me it's the tires
Old Sep 26, 2005
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Yep the Hankooks baby. I had two sets of H106's - 215/35/18's and now my 205/45/16's
They take a static and dynamic balance. A sticky weight must be used on the inside aswell as weights on the inside lip of the rim. I tried hub rings too and no difference. Most tire shops don't have very experienced workers, especially ones with tuner wheel and tire experience. I had 5 balances on the 18's and they final ran smooth as silk 110+mph the 16's took 3 times and they run very smooth except on bad roads of course. Find a good shop and explain your situation.
Old Sep 26, 2005
Tbag's Avatar
What tires should I get?...I'm looking at the Fusion Bridgestone
Old Sep 26, 2005
cg95660's Avatar
^^my next tire is going to be the nitto neo gen's. They are designed for negative camber. Plus they look coo. Maybe some one here has run them and they could comment I would like to know too.
Old Sep 26, 2005
I have them on my 17's. I love them, and they are SUPER sticky.
Old Sep 26, 2005
burke420's Avatar
The World Is Yours!
i was going to go with the Neo-Gens till i saw the treadwear rrating at 280, so i went for some Falken Zeix 512, they are rated at 360 and if you got a camber problem got a camber kit, its worth it IMO. i have one and my tires last way longer than they ever could. plus the 2 tires should be the same price so therefore tires will last you longer on life.
Old Sep 26, 2005
sofabolous's Avatar
sofabolous is an unknown quantity at this point
my steering wheel is also an earthquake 60+ with my 17's
Konig Verdicts w/ Neos
Old Sep 26, 2005
pon55's Avatar
"Any" low profile tire is hard to balance!
Like the man said, find a shop that knows how to do it!
Old Sep 26, 2005
tchou's Avatar
tchou is an unknown quantity at this point
I never had any problems with mine. Seriously, u just gotta find a good shop.
Old Sep 27, 2005
Tbag's Avatar
That's tuff to find in Charleston, SC...if at all
Old Sep 29, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Are you sure your rims are not warped? Better check the runout first before continue with the balancing.
Old Sep 29, 2005
TemjinX2's Avatar
just rebalance them. I have 17's on kumho 711 tires and there fine until 100-110mph. Before someone flames me for speeding on the freeway. This was on open road where you can see about 5-10miles ahead of you and no one was on the road.
Old Sep 29, 2005
acidbaby's Avatar
The Beez Kneez
could it be that the rim might been off? i bumped into a curb and threw off the balance of the whole rim slightly.
Old Sep 29, 2005
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
check your struts...usually the metal rod of your shocks might be damaged or there is something wrong because that wat happened to my moms truck...one day it may jus give in very dangerous
junkyardguy
Sep 2, 2015 06:07 PM
sccarally
Texas
Aug 21, 2015 10:09 PM
