Lugs giving me a hard time
Old Sep 1, 2005
Ledbelly's Avatar
Im the man in the box
I've had this problem for a couple of months now. It's kind of on and off. 2 lugs on the driver side front tire keep coming loose. This started about the last time I rotated my tires. I'll tighten down my lugs ( Spline drive) and after about 2 miles the same ones come loose. After tightening them down and driving a little they came loose again so I switched some lugs around to find out if it was the stud or the lugs. Anyways I switched the 2 loose lugs in the front with 2 lugs in the back... drove on it and they stayed tight for about a month. This morning driving back from school I hit the brake and feel/hear a little clank clank clank. Sure enough the 2 lugs in the same spot are loose on the front driver's side tire are loose. Now here’s the question. What are my options, what do you suggest? If I could I would change out the whole setup since it is time for me to be changing my fluids and brakes but with college money is a factor.
Thanks in advance
John
Also my wheels are 16inch Rotas and I'm not sure what the brand of lugs are. I bought both off Prod about a year ago.
Old Sep 1, 2005
djmota's Avatar
sounds like your aluminum lugs are wearing and loosening up. buy some steel ones or higher quality aluminum
Old Sep 1, 2005
rEkKaShInObI's Avatar
Unsalvageable
you sure you didnt accidentally strip them some how?
Old Sep 1, 2005
Ledbelly's Avatar
No they arn't stripped. I've checked and rechecked this many times. There is some rust inside the lugs and on the stud.
I'd like to take a look at it this afternoon but I'm not sure if I can it's supposed to rain. If I do I'll be sure to take some pics of the studs and lugs.
Old Sep 1, 2005
joelwastaken's Avatar
joelwastaken is an unknown quantity at this point
Get some blue loctite and squirt a lil bead down the threads. They shouldnt loosen at all then and its non permanent.
Old Sep 1, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
are you tighting it the right way???? as in cross
Old Sep 1, 2005
dru106's Avatar
ThE CoRRupToR
Are you torqueing em correctly?? Remember, 80lbs
Old Sep 1, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
if u are hand tightening them down thats yer prob but you prob arent doin that. u prob just dont have em torqued down pretty good.
Old Sep 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Not smart. Loctite blue takes 150 lb-ft to break loose. You don't want to be cranking aluminum lugnuts with that.
If they're aluminum, the threads probably stretched because someone overtorqued them at sometime. The only way to fix it is to replace them. They're rusty because the threads aren't meshing right and water is getting in there... thats a sign of something being wrong, because they should seal.
Spline drives are notorious for not holding their torque, so I'd just suggest ditching them for some better lugnuts. Steel lugnuts are cheap as hell and hold torque really well.
Old Sep 1, 2005
pon55's Avatar
^^Is there any car question you can't answer?
Great call, I've actually seen steel lugs do it to.
Old Sep 1, 2005
Ledbelly's Avatar
What lugnuts would you suggest ? I havn't really looked into them or shoped for them before. The ones I have now I got off prod because he had an extra set.
edit:/ I have Rota C8s if that makes a diffrence. Which I'm sure it does, the holes are kinda deep.
Old Sep 1, 2005
Jap-Euro Fusion
It makes a difference in that you probably need tuner style lugnuts (thin shank). Whats good? Hell I don't know whats good and cheap. Zenki nuts are pretty good, they're probably 60 or 70. When you get into the nuts for the tuner type holes, your options become limited, most of the good nuts are for racing wheels with big open hub decks. Mcgard must make something.
And the car questions I don't know... when you race a car, you know it like the back of your hand. Simple things like this have simple answers. You can't overtorque bolts... **** like this happens if you do.
Old Sep 1, 2005
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
Gorilla or McGard spline drive lugs are good. Rust resistant, and are tough as anything. I've had the gorillas for 3 years now and they still look great. Keep in mind I live in Canada and have to swap for my winters and back to summers every year, so they're definitely taking some abuse.
Old Sep 2, 2005
tfnaaf's Avatar
BLDNPSI Mod
check for rust on the rotor face, and corrosion on the back side of the wheel where it meets the rotor and with proper torque they should never come loose
Old Sep 2, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Aluminum rusts?
Old Sep 2, 2005
tfnaaf's Avatar
BLDNPSI Mod
Originally Posted by dariusld
Aluminum rusts?
it will corrode , yes
Old Sep 2, 2005
Ledbelly's Avatar
What about these LINK I have to admit I'm kinda in the dark on shopping for these things.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
Ninetyatecivic
May 9, 2015 07:48 PM
bsmiley
Apr 27, 2015 01:27 PM
silvercallx
Aug 19, 2001 12:36 AM
