whats the right psi?
Old Aug 31, 2005
slicksivik's Avatar
well i have 215/40/16 tires on my 16'' wheels and it says max 51psi. well i dont kno whether the psi is right or not, but i want to kno where to set it at, because i looked on my tires and there worn in the middle more then the sides. maybe its cuz i have them inflated too much?? i think its set at between 40-44 psi. TIA btw, there falken ziex 512.
Old Sep 1, 2005
Whelan's Avatar
Whelan is an unknown quantity at this point
Im not sure about low pro's, that does seem like a lot of psi for the small tire but it could also be because it i a low pro that it needs more pressure to compensate. I typically see what the tire is and go about 2-4 below that number as that is the max, so a little below has always worked for me.
Old Sep 1, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
if you call the tire company, they can usually tell you what the recommended psi for your size car is with that particular tire.
Old Sep 1, 2005
Zzyzx's Avatar
Autocross Junky
Tire PSI is based on vehicle weight... and the recomended PSI is posted in the driver side door well. if you have low profile tires, the general concensis is to increase PSI by 1-2 LBS per wheel size larger then stock.
So, if stocks were 15, and the recomended psi is 30, then with 16's you should be running 31-32 PSI....
Old Sep 1, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
wow, 51?! my ZE 512's say 40 max.....
Old Sep 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
The Max PSI is just a rating that they recommend not to exceed before the bead blows off. its NOT what you're supposed to run the tires at. It says in the door to fill them to 30. So maybe you could go for 32. But 51?
Old Sep 1, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
uh with any tire u never want to hit that max amount of psi the tires tell u. NEVER. even goin up to 40psi is dangerous enough cause if u drive around with that amount of pressure in yer tire and u hit a bump of some sort then yer askin for a buldge in the tire or a tire exploding. i recommend puttin any standard load tire or even performance tire between 32-35psi
Old Sep 1, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
i would go with 100 psi like hunter s thompson did in the caddys he drove
Old Sep 2, 2005
Ledbelly's Avatar
Im the man in the box
I keep my 16s at 34. Also remember to check your pressure when the tire is cold
Old Sep 2, 2005
chrisleecool's Avatar
this kinda topic has discussed numorous times i believe
no matter what the wheel sizes are,
anything from 30~35 should be fine (normal) , u don't ever want to go w/ max psi evEr....
I've set mine (215/40/18) at 32psi all around and it rides fine not too bumpy not too soft.
Old Sep 4, 2005
slicksivik's Avatar
thats interesting, i've always run my tires at 40-44 all the time and never had a problem, whether it be my 16's now or my 17's i had. maybe thats why its always bumpy lol. i have em set between 30-34 now tho.
Old Sep 5, 2005
civic-king's Avatar
civic-king is an unknown quantity at this point
you can run at max psi, these people are silly... max psi is for max load. if you have a system, and your trunk is full of crap, and your backseat is full of crap, and you have a fat guy in the passenger seat, i would recomend 50 psi no problem. the door placard (sticker) says 30 because that is for ride comfort. if the center of your tire is going bald, your pressure is too high for your specified weight. let out 4-5 psi, and check the tread in a month. regulate them accordingly....
Old Sep 5, 2005
slicksivik's Avatar
oh well, for some weird reason, one of my tires is bald as can be. i guess i need a new tire and its only been a yr. thats friggin strange. the other 3 tires are just fine tho. and i swear i had an alignment done too. damn friggin tires.
Old Sep 5, 2005
crazyasian's Avatar
decided not to care
Old Sep 9, 2005
dru106's Avatar
ThE CoRRupToR
Originally Posted by crazyasian
decided not to care
Haha!! Seriously, go ahead, do 50
Old Sep 9, 2005
slicksivik's Avatar
well i changed the one bald tire and i lowered all psi to 25 in order to even out the wearing in the middle, cuz the outsides are quite fine, so i hope that takes care of the problem at least for a few months. i took the psi tonight cuz it was cool and the tires were cold, so it said 25psi all around. hope thats low enough to do something. i wont go lower, i mean 20 psi is just dangerous i think.
Old Sep 20, 2005
philmcneal's Avatar
philmcneal should not be trustedphilmcneal should not be trusted
hm my civic coupe se 14's says recommend 30, but i do 35 for front and 33 for the back (tires are warm, weather was normal)
car weight about 2400 pounds + me (130) pounds
when its going blad what does that mean? like i'm eating more rubber or something? what's the science behind it.
Old Sep 20, 2005
Zzyzx's Avatar
Autocross Junky
Check your alignment... if one tire is bald and the others are not you may have a Toe issue.
Old Sep 26, 2005
burke420's Avatar
The World Is Yours!
if you go upp to 50 or so you risk a blowout at anytime, i mean hittin a pothole would explode the tire. 32 for compacts is the safest regardless of what a maxload indicates. that is better for when u got leaks and what not to last it a lil bit longer.
Old Sep 27, 2005
keitaro's Avatar
keitaro is an unknown quantity at this point
i run at 32, but if you are racing, you can bump it up high to achieve a stiffer wall which can handel better is some turns.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
mjdiaz89
Jun 21, 2016 09:26 PM
rezsst
Sep 26, 2015 07:04 PM
NROD315
Sep 12, 2015 02:46 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
