i used the tire calculater on the site and i was looking at 18''s and they when i was just punching different numbers they came out even with no differnece in tire rotation no speed differences
it said oem on the EX was 185/65-15
and i used the numbers 205/40-18 and they were identical sized on the outline thing
i was just wondering if they would be the same when u put them on the car for turning radius and would they have tire rub
the widest rim a 205 sized tire can fit on is 7.5" wide that i know of. im sure you can fit a 205 wide tire on a 8" wide rim, but it'd look pretty funny?
with 205 wide tire, it wouldn't rub. but with a thick sidewall (40 series), i think theres possiblity it could when turning. thats where if your dropped or not becomes a factor as well.
205/35/18 will work, but if you want to feel every bump in the road, be my guest. I got 225/40/18 on my civic and it rides real smooth. If you don't drive your car that much then that might be ok for you.
Quote:
Originally Posted by HondaSales
mine is dropped on a 215/40-18 and is not eve close to rubbing Quote:
2 week old thread..who cares..Originally Posted by B Rich 157
205/35/18 will work, but if you want to feel every bump in the road, be my guest. I got 225/40/18 on my civic and it rides real smooth. If you don't drive your car that much then that might be ok for you. what are you guys dropped on? im on neuspeed sports and tokico hp's...
