lug nuts for axis seven mods????
ok i tried to put my axis seven mods on today but i realized my lug nuts to my older rims (motegi mr7's) wouldnt fit these rims...and i also tried the stock lugs....i mean....the lugs fit in and everythign its just when i go to put the center piece on to HIDE the lugs the piece wont go on cause the lug nuts are blocking it.......anyoen else have this problem and if so...where can i get some logs to fit these???
you probably need the little shorty nuts. They're open ended and the stud is probably longer than the nut is. Go to Discount tire or something.... they should be pretty easy to find.
Fiji Club Member
post some pics of ur ride when u are done installing..
Never Too Wide, Never Too Extreme
yeah. I had that same problem with my axis seven mods. what boilermaker1 said was right. you're gonna need the open ended lugs. Once you get those, then the caps will go on with no prob.
alright thanks guys.....ill post up some pics when i get the lug nuts...my car goes in the shop monday to get a bmw jet black paintjob and im gonna have them just throw on the rims as well....thanks again
ricer_em2
May 11, 2016 08:09 PM
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
