Need help on tires
Old Mar 20, 2005
civicdragster02's Avatar
civicdragster02 is an unknown quantity at this point
Question Need help on tires
hey guys I need your opinion on what
tires are the best for the dragstrip ( slicks or drag radials)
Thanks
Old Mar 20, 2005
LowSky's Avatar
I spend way too much time on this website
LowSky is an unknown quantity at this point
they are called drag for a reason...plus since its a FWD you only need them for the front
Old Mar 20, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
You probably won't need slicks unless your ride is pounding out 400+ HP. Drag radials will do you just fine and lowsky is correct. You only need them for the drive tires.
Old Mar 20, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Slicks will be stickier and softer, but the liklihood of needing that kind of grip with as little torque as the car makes is virtually 0 like they said, in which case drag radials, which are less expensive would be a better option.
Old Mar 21, 2005
Thanks for thee input
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
