Widest tire on 14" steels?
Old Feb 28, 2005
LiKEaFeRiO's Avatar
I have 195/65/14 Falken Ziex ZE-502s right now but they are due for a change soon.
I was wondering whats the widest tires I can put on 14x5.5 steels?
I also plan in lowering my sedan with some H&R's + Tokico HP (blues).
205/60/14
I found one old thread where someone said this will fit.
Its over 2% off though.
Won't give me problems with rubbing (hopefully).
215/60/14
Not sure if it'll fit right on a 5.5 wide rim.
Good news is that its only .3% off.
Chance of rubbing after lowering?
The tires I'm leaning towards in these sizes:
205 - Falken Ziex ZE-512 @ $49 each from tires.com
205 - BFGoodrich Traction T/A H @ $61 each from tirerack.com
215 - Yokohama Avid S/T @ $47 each from tirerack.com
Thanks in advance
Old May 4, 2005
cdmx's Avatar
$43 at www.edgeracing.com
Old May 5, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
old thread.
205 would be widest as for 5.5" width. maybe not, but i think it could be possible depending which tire as some brands over rate their tire specs.
IE: a bridgestone 195/55/16 tire can be a little wider than a yokohama 195/55/16
Old May 5, 2005
2k2civic's Avatar
I believe optimum wheel width for a 215 tire is 6.5", but if I remember correctly, a 215 will fit a 5.5" wheel.
Old May 6, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
205/60/14
215/60/14
Thanks in advance
how could 2 rims with the same 14 inch 60 series have diff tire readings?
Old May 6, 2005
not readings but i meant, uhh u know the tire calculator
SidCivic
Oct 3, 2015 06:00 AM
mikey1
21
Aug 27, 2015 06:38 AM
alaga
25
Aug 13, 2015 04:42 PM
jedi
Aug 3, 2015 04:26 PM
BootyDo
Jul 7, 2015 06:06 AM
