13s on 2001 civic ex
Old Jan 29, 2005
macrossranma's Avatar
macrossranma is an unknown quantity at this point
Hi, anyone know if i can fit 13" rims on a 2001 civic ex?
thanks!
Old Jan 29, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
and why are you downgrading to 13's?
Old Jan 29, 2005
Jrfish007's Avatar
13"? I doubt it.... has anyone here even put 14" on an EX for long period with out waring down the brake lines?
Old Jan 29, 2005
hustlelikem0fo's Avatar
thanks!
are these 13s 12-inches wide and have 100 gold spokes?
Old Jan 29, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
Talking
thanks!
Why are you trying to lower it, or make it seem faster? what is the point of going with such a small rim?
Old Jan 29, 2005
Zzyzx's Avatar
Autocross Junky
Small wheel = Low Rotational Inertia = Faster acceleration. Tie that in with a "Short" tire, and you effectivly shorten the gearing of the car = Even Faster acceleration. and if its a wide wheel.. like a 13X7.... then you'd be even better off. Esentially, for racing, be it Drag or what not, you want to run the smallest wheel you can fit over your calipers. but unfortunatly for us, Im pretty sure the smallest we can go is 14"
Old Jan 29, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
my friend with junkyard turbo has 13s with slicks because he goes to the track alot. He got better time by me but not by much but when we race in the open, i usually take him by couple cars.
Old Jan 29, 2005
QBoi's Avatar
With your NOSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
Old Jan 29, 2005
Caucasian.Asian's Avatar
i think the only 13"s i've seen are no name brands. i would just go with some light weight 15s
Old Jan 29, 2005
anibal's Avatar
anibal is an unknown quantity at this point
The smallest you can go is 14-in. due to caliper clearance. I'm sure, I have 14-in. Brake disc diameter is the same in all 7th gen models.
Old Jan 29, 2005
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
volks makes 13's, advan makes 13's, if you look around there are a few companys that make 13's.
and 14's are the lowest we can go.
Old Jan 29, 2005
BoOsTaNiGgAh's Avatar
BoOsTaNiGgAh is an unknown quantity at this point
yea so im throwin the type s suspension on my 03 civic ( yup 4 lug to 5 lug) so the kid is giving me everything but the axles and i dont think the sohc axles will work. will the type s axels slide into the d17?
Old Jan 29, 2005
i'll get 14" than, the reason i want to get the smallest possible because i need to need get whats best for solo2, im already max out my points, and the wheels is the only thing i can do, currenty running 15" ra1, wanna change to 13s hoosier or the new v710 and save the 15" for track
Old Jan 29, 2005
hotrodcivic2004's Avatar
my civic has no boost
i saw the title and thought he ment 13 second.......
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
