Tire Matching Question
18" X 7.5" ADR GT-Sport wit +42mm
wit 215/35/18 tires?
Is this enough info?
I'm not sure...I don't kno enough bout wheel n tires.
How can I tell if the tires are the right width?
Well thanks for any help.
That size will fit under the fender. Only concern I have is with that offset, becareful you are not hitting your suspension (the springs). Stock offset is 35, you stated 42, so you've brought the tire 7mm closer to the srpings, make sure that is okay, and you should be fine.
Originally Posted by Kizuel
Stock offset is 45
It's a pretty good price for a set of 18's with tires from what I've seen, but I've also heard not to great things about Wanli tires. You may want to spend the extra $15~$20 per tire for a better brand.
I haven't been looking into 18's that much, but 215/35 seems it would bit short and will leave you with very little rubber between your rims and the ground. IMHO, 215/40/18 would be a safer bet.
Oh and stock offset information can be found in the FAQ at the top of the page:
http://www.7thgencivic.com/forums/sh...d.php?t=138976
Touge
Jun 18, 2015 11:44 PM
bo_red
Apr 23, 2015 10:09 PM
