tires not holding air?
i have yokohama tires which were rotated and inflated about 3-4 weeks ago. today i checked the psi and all 4 were almost 10psi under inflated. i had them filled to about 41psi and now they all were about 33-32psi. whats going on? i checked to see if maybe the odds were against me and i somehow had a leak in all 4 tires but i didnt see anything. is this normal? i never had to fill my stock firestones this soon.
Either the tires aren't able to hold high pressures, or you have a slow leak around the bead of the tire where it seals against the rim. They may not be fitting right.
yeah, take it to a tire shop and they could put some sealent on it to stop it from leaking. if you have a pool or a big tub, put one whole rim in there and look where the bubbles come from. that will be where your leak is. might be the valve too.
jc33312
May 12, 2015 03:17 PM
bo_red
Apr 23, 2015 10:09 PM
