Tires are going bald...wtf??
Old Sep 17, 2004
tripledoublegs's Avatar
Euro-Spec
damn, I just noticed today my front right tire is going bald on the outside. Is that negative camber or what?? I had an alignment a couple months ago, and I have hayame full suspension, w/ camber kit. I don't get it... How can I get negative camber? Someone help me out. Thanks
Old Sep 17, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Its probably toe in. That'll eat outer shoulders. Get your alignment checked again.
Old Sep 18, 2004
Mr.Modify's Avatar
yikes sucks! i don't have that problem of any sort....seems like it's people with Full Coilovers :dunno: this isn't the first time i heard of this with full coilvers....what gives?
I got sleeved coilvers and im fine and dandy prolly lower also.
Old Sep 18, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
I have B&Gs and do not have that problem. Sounds like you may even have positive camber wear. Negative camber wear is when your tires wear out more on the inside.
You can tell whether it's toe or positive camber by looking at the way it is wearing down. Bad toe would cause a type of "feathering" wear. This is where you see raised and low spots on the part that outer edge wearing down. This is because bad toe causes your tire to skip. Hence, some parts of that edge is high and some low.
Positive camber would result in the same spot wearing down, but more evenly instead of that up and down wearing.
Oh, and to add one thing. Did you possibly hit any potholes or nasty road conditions. It may easily cause misalignment.
twd000
Oct 4, 2015 12:52 PM
SidCivic
Oct 3, 2015 06:00 AM
siliconvalley
Sep 15, 2015 09:48 PM
alaga
25
Aug 13, 2015 04:42 PM
