tire number meanings..
Old Jul 20, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
i remmeber seeing a post about this a long time ago.. tried earching bt cant find it ne more... but ne wayz
EX: 185-65-15
What is 185 and 65 measured in? is it MM?
Old Jul 20, 2004
Zzyzx's Avatar
Autocross Junky
Simply the best explination...
http://www.tirerack.com/tires/tirete...nformation.jsp
Old Jul 20, 2004
zen_master's Avatar
very ibtl.
should go to tire and wheel's FAQ..
anywho..
185 = wide
65 = ratio (meaty or not meaty)
R15 = radius....
i want: 215/45/R17
Old Jul 20, 2004
Zzyzx's Avatar
Autocross Junky
^^ actually the R means that the tire is of Radial construction, and the 17 is the Diamiter in inches...
Old Jul 20, 2004
zen_master's Avatar
^^ah, diameter....LOL...hahahaha
thanx for the info, Z!
Old Jul 20, 2004
SuperFrankie's Avatar
SuperFrankie should not be trusted
here is something nice that i found in a book
Tire Size Markings...
All tires carry standard tire size markings on their sidewalls, such as "195/60 R 15 8H"
195 indicates the width of the tire in MM
60 indicates the ratio of the tire section height to width, expressed as a percentage. If no number is present at this point, the ratio is considered to be 82%. this section ratio is also called the aspect ratio or the "profile". a low number here means a low profile tire that won't be as tall as higher-ratio tire
R indicates the tire is of radial ply construction
15 indicates the wheel diameter for the tire is 15 inches
87 is an index number which indicates the max load the tire can carry at max speed
H represents the max speed for the tire, which should be equal to or greater than the car's max speed
*NOTE*some tires have the speed rating symbol located between the tire width and the wheel diameter, attached to the "R" radial tire reference, for example, "195/60 HR 15"
Speed rating symbols for radial tires
Symbol - MPH
P - 93
Q - 99
R - 106
S - 112
T - 118
U - 124
hope this helps some
alxz310
Jul 30, 2015 12:18 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
