What's the Centerbore for Circuit 8's?
for 16's ....i know slipstreams are like in the 60's but what about the Circuit 8's ? Anyone with Circuit 8's that got Hub Centric Rings what's the size that was used?
Hopefully this clears some things up for you....
CENTERBORE:
The centerbore of a wheel is the size of the machined hole on the back of the wheel that centers the wheel properly on the hub of the car. This hole is machined to exactly match the hub so the wheels are precisely positioned, minimizing the chance of a vibration. With a hubcentric wheel, the lug hardware will not be supporting the weight of the vehicle, all they really do is press the wheel against the hub of the car. Some wheels use high quality, forged centering rings that lock into place in the back of the wheel. This is an acceptable alternative.
If you have non-hubcentric (lugcentric) wheels, they should be torqued correctly while the vehicle is still off of the ground so they center properly. The weight of the vehicle can push the wheel off-center slightly while you're tightening them down if left on the ground.
CENTERBORE:
Originally Posted by jackal903
hey, i need to get a set of hub rings for my 17'' rota subzero 4x100 also. does anybody know the Centerbore of my rims? thank you
mjdiaz89
Jun 21, 2016 09:26 PM
Bruce2
Sep 21, 2015 08:01 PM
Touge
Sep 18, 2015 12:13 AM
JMKendrick
Sep 16, 2015 06:17 PM
Touge
Jul 28, 2015 09:46 PM
