lug nuts help
Old May 9, 2004
CivicS's Avatar
CivicS is an unknown quantity at this point
lug nuts help
For Honda 03 EX Si rims, its 12x1.5mm or 12x1.25mm? i'm looking for good lug nuts for Si rims. cuz...currently i put those lug nuts that was design for LX hug cup wheels, which nuts not fit all they way to the wheels.
pls let me know where i can find some good aftermarket wheels nut for Si rims....or some OEM nuts.
thanks, very appreciated.
Old May 9, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
M12 x 1.5 application: Fits Hondas, Acuras, Toyotas, Lexus, Mazda, Mitsubishi etc.
M12 x 1.25 application: Fits Subarus, Nissans, etc.
Old May 9, 2004
Ershall's Avatar
tuner nuts?
www.evasivemotorsports.com
DO NOT buy Kyokugens.
Old May 9, 2004
Ershall's Avatar
Muteki seem well made, light, strong, they don't strip after you take them on/off once or twice like Kyokugens do.
Old May 9, 2004
CivicS's Avatar
thanks for quick reply !!!
Old May 9, 2004
Ershall's Avatar
no problem.
Old May 9, 2004
CivicS's Avatar
i saw some guys selling Acura lug nuts on eBay, do you think that 2004 Aucra TL lug nuts will fit on Civic Alloy Wheels?
for Tuner nuts, u recommended: open ended or close ended.
Old May 9, 2004
Ershall's Avatar
I'm not sure about the TL lugs..they look a little big though.
Personally, I like open ended but it doesn't really matter.
Old May 9, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Ummm, all honda wheels use the same nuts. They're all ball ended. The hubcap nuts go into the Si Wheels, you need to just pull the plastic ring off the nut if it comes out with it.
Old May 9, 2004
CivicS's Avatar
so hubcap nuts are oky on Alloy wheels right?.maybe next time when i rotate my tires, i'll take them off..... i really want make sure that lug nuts are properly secure on studs......
so Civic lug nuts sizes is: 25mm, 30mm or the 35mm? which one better fit on Si rims.
also do you think if i invest on Muteki open ended lug nuts around $40 a set, do you think it worth my money? are they striping very easily
Old May 9, 2004
Jap-Euro Fusion
Ok, you don't seem to understand this. EVERY Honda wheel uses the exact same ball nose on the nut. There are 2 kinds. The ones for exposed lugnuts and the ones that are shorter so you can put a hub cover over them. Everything from the Insight to the NSX comes with the exact same nut. All Honda wheels use ball nose lugnuts regardless of whether they are steelies or forged aluminum. You do not need new lugnuts, the design of the Si wheel makes the nut stick out a hair because the center depresses in. The only lugnuts I know of that fit and aren't made by Honda are made by Spoon, and they're $7 each, and you need 16 of them.
Raiool
Oct 1, 2015 10:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Hollywoodsnake
Sep 20, 2015 12:58 PM
stank
Sep 16, 2015 07:40 AM
siliconvalley
Sep 15, 2015 09:48 PM
