would you be able ???
this is my question.
i know it been ask a whole bunch of times, and i also done a hugh search on this...
okay here goes. i have a 2004 acura el, which is like a 2004 honda civic.
but my car come with rear disc instead of drumms..
would i be able to buy just the wheel bearing, and rotor to convert my 4 bolt to 5 bolt..
instead of buying the whole rsx suspension
Its a celebration bitches!
i beleve that you can only do that for the rear, but for the front if you have the d17, you will need special axels, because the k20 uses diffrent axels that teh d17.
i would only suggest that you do a 5 lug swap if you get a k20.
you can get some axels special made, but that would probly cost alot of money.
