Bent a rim!
Old Feb 25, 2004
BobbyStylz's Avatar
BobbyStylz is an unknown quantity at this point
Bent a rim!
Any one know where I should go to get a rim fixed in the philly area.
Thanks
Old Feb 25, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Just buy a new one... there really is no way to fix an aluminum rim, it'll crack.
Old Feb 25, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
yo this place is right by me... 109 bucks and its new. weither bent, cracked needs paint, cc , WHATEVER.. 109.00 flat fee... rims come out looking new...
http://www.fixrim.com/loc.htm
Old Feb 25, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
if its not pep boys or autozone u wont find it here in Philly. we have rip off shops and nothing else. wheelworld on baltimore ave is a good place i go to. they hook me up wiht wheel unmounts, mounts, and balancing.
Old Feb 25, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
so how bad is the bent, if is bad there is really no need to fix it cause it will never be the same.
Old Feb 25, 2004
Jap-Euro Fusion
I love how they claim they have this process and machines, but don't tell you anything about either lease: .
Anyways... I wouldn't trust a rim that they've welded back together. Its just going to crack again. Welds are weak points, especially if they're in places they aren't intended to be and the rim has a stress riser in it from where it already got dented and cracked. And for 109, unless you're rolling on $300 a piece rims, it makes more sense to buy a new one anyways. It may look better, but it won't be nearly as strong, and a painted or powdercoated finish will never match the other 3 (thats why all their before/after pics are of polished rims). So you're looking at repairing 1 and refinishing all 4. Ends up being $250+tire dismount/remount by the time you're done.
Old Feb 25, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
^^^ its warrenty'd 4 life son.
Old Feb 25, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
thats an uneducated answer....
and boiler.... my rims were 495 each-
welds are stronger then the orginal-
Old Feb 25, 2004
Jap-Euro Fusion
You care to explain how filling a void in the grain structure with a material that doesn't have the same chemical make up as the rest of the wheel and leaves a seam where its joined to the remainder of the wheel, in a place where there wasn't intended to be a void is somehow stronger than the original? I can't possibly see this being true, it makes no mechanical sense. Any time you can avoid a seem, joint or any other potential stress riser or weak point, you avoid it, thats basic design. Otherwise they wouldn't be forging race wheels from solid billet, you're saying they could patchwork them together from scraps and it would be just as strong.
And great, so there's a guarantee... I can **** in a box and put a guarantee on it. How many times would you want to send it back? If you're hard on them, you're not going to want to be driving on a repair.
This is the same thing as racing on plugged and patched tires... sure you could do it. But its not smart, its never as strong as the original, there's a hole in it, and the tire is compromised... same thing applies here.
Old Feb 26, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
LMFAO...TOMMY BOY!!! ... well...kinda, lol
Old Feb 26, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
first off.... your retarded. i live a town away from one of the places, second. its guaranteed.. .MEANING.. NO u dont wanna send it back a million times.. MEANING that they stand by their work and KNOW that if they FIX a rim and guarentee it.. that its as good as new.
explain another reason for that? cause id like to know how they stay in business then.
Old Feb 26, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
why are u so against someone providing a service... just because u dont understand or know their methods.. means their no good.... typical from someone in the mid-
Old Feb 26, 2004
Jap-Euro Fusion
No, just typical of an engineer. Anyone who's spent the better part of 4 years reading and solving this **** should know that you can't fix something and make it as strong as new. Its NOT POSSIBLE. You find one mechanical test where someone has proven that a welded repair is stronger than an original monoblock piece.
I deal with this **** all day. I work for an orthopedic company that makes replacement joint implants, we make our own castings. Any casting that has any sort of inclusion MUST be scrapped. We're not allowed to weld the inclusions shut because it leaves a seam. Seams cause stress in the part, they cause fractures and failures.
Most parts we weld are also pinned into place because the weld itself is not as strong as a mechanical lock in place. We usually pin pieces together then just tack weld over the pin head to hold it there. Welded brackets snap off all the time, if you machined them into the part they're much stronger. Welding is just cheaper... thats why they do it. To mass produce complex parts on a wire EDM or a mill so they come out as one piece is just cost prohibitive. Its far simpler and cheaper to stamp or cast out pieces and weld them together.
BTW.... I'm from New Jersey. I just happen to live out here.
But if someone isn't going to give you even a vague explaination of what it is they do, then why would you trust them? All they're doing is a cosmetic repair. They're not taking the mechanics into this at all. You find me one person who would be willing to risk themself and their car by pushing hard on a repaired cracked wheel.
Old Feb 26, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
its just weird that ur so quick to jump on them for... what reason? have you sent wheels to them before? or even bothered to give them a call?
Old Feb 27, 2004
Miss_Hatchy's Avatar
Miss_Hatchy is an unknown quantity at this point
Agreed. Most of the time it's safer and more cost effective to just replace the wheel...especially since you have to unmount/mount anyways
Old Feb 27, 2004
CTICE's Avatar
CTICE is an unknown quantity at this point
I bent my chrome wheels and had the city pay for it. They were doing construction on the road, and had no signs that said there was a bump. If you hit a pot hole or something they may do the same. But the tire place said there wasnt anyway to fix a bent wheel, it would still vibrate a little bit on the freeway.
Old Feb 27, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
should it be a new rim or a repaired rim? hmm, who cares just do whatever you want. how about that one? you guys are jokes
Old Feb 27, 2004
He was asking about safety and integrity of the repair...so if he wanted to "do whatever he wanted", he wouldn't have asked in the first place.
Old Feb 27, 2004
Honda2k4's Avatar
well than buy a new rim, its safer
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
rainman15
Sep 6, 2015 11:10 AM
