Burning out.... tread loss?
Old Jan 16, 2004
Project2k2's Avatar
JUst as the title says. I want to know if you lose a lot of tread when you burn out, not just normally, but in a water box at the drag strip. Is there any difference between just regularly burning out and burning out in the water box treadwear wise? Any info would help.
Oh and also. SInce I am going to the track tommarow. SHould I put on my stock fronts. Or run with my 17's. With my 17's before I ran a 16 flat. Would my stocks make that much of a difference?
-Derek
Old Jan 16, 2004
Zzyzx's Avatar
Autocross Junky
The tread loss is probably comparable to normal burn outs, the water just makes braking the tires loose easier.
as far as your stocks out performing the 17s, well that depends on how sticky the rubber is that you have on your stocks.... Yes the stocks will have a lower rotatioal mass = more power to the ground but if the tires cant take the power you'll just spin the tires longer....
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
beanhead
Sep 24, 2015 12:04 PM
