RPF1's
Old Dec 10, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
RPF1's
so i'm thinking of getting these wheels
instead of speed masters (they don't actualy weight 10.5 lbs), but what would be a better offset +35 or +41, since they're a 7 inch wide rims..
thanks...
Old Dec 10, 2003
Zzyzx's Avatar
Autocross Junky
its a good racing wheel. especially the 15X7, Very popular in spec Miata racing.
Old Dec 10, 2003
robbclark1's Avatar
Retired suspension supermod.
those are nice...maybe I will steal that idea from you! muhahaha. I am not sure about the offset....maybe boilermaker would know
Old Dec 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Exclusively for racing, 35mm (unless you run a stock class). Wider is better. For double duty, 41, but verify with Enkei beforehand that the calipers clear. There are issues with a lot of cars (Minis, ITRs, Miatas, WRXs, and more) have caliper-spoke collisions with the stock size diameter. The spokes are thick and curl in at the lip... it causes problems. Find a place that stocks them and check the fit before you buy. I would be very cautious in checking the fit first and being absolutely certain that they fit right.
Old Dec 10, 2003
Zzyzx's Avatar
Autocross Junky
If they don't clear the calipers, you can pick up some spacers from H&R, wider Really is better. one of the guys I race with has an STi and he picked up some rotats...... they cleared the rear brakes but not the front. scraped the caliper. so he picked up some spacers and... problem solved.
Old Dec 10, 2003
so witch one would have more problems with clearence??
and no one stock em here in mexico so i'm screwed
also i'm thinking of having em poedercoated black, doe any one know how thr Enkei logo is on the wheels??
painted or sticker??
Old Dec 10, 2003
Jap-Euro Fusion
I believe it's a sticker, but if you get them done black, a black sticker won't do much good.
the 35mm will have LESS problems with caliper clearance issues, but they're going to stick out a hair. You'll have fender rubs if the car is too low.
You might want to try the 41 with the 5mm spacer. I don't know. I've never tried to fit them on a Civic, I honestly couldn't tell you if they'd clear or not.
Old Dec 11, 2003
here's something i don't understand if i buy +41 offset and they dont fir, when i get the 5mm spaces wouldn't that bring it to the same as 35 offset and then it would rub??
Old Dec 11, 2003
Zzyzx's Avatar
Autocross Junky
I dont think you are going to have a problem whith these fitting, a lot of the older civics run these for autocross. and we share a lot of the same brake parts. So it should fit, at least in theory.
Old Dec 11, 2003
so the both could fit...
doncarbone
Jun 8, 2015 03:37 PM
Twenty 110
Apr 16, 2014 05:45 PM
EM2typeflex
Feb 10, 2013 07:44 PM
hankcui
Sep 22, 2012 11:22 PM
sleeper2002
Jun 21, 2005 05:02 PM
