width & weight
Old Nov 6, 2003
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
width & weight
3 questions
1) What is the widest tire i can put on the stock DX steelies??
2) How much do the stock steelies weigh with no rubber??
3) What would be the best profile for rubbers intended purely for track use??
Old Nov 6, 2003
Zzyzx's Avatar
Autocross Junky
what type of track use? Road course or drag race????
how wide are the DX wheels? Ive seen people shoehorn 225s on to a 5.5-6" wheel. stock steel wheels weigh about 18 LBS.
Old Nov 6, 2003
02civic's Avatar
and by track i mean drag....i'd like to be able to pick up some rotas but if i cant $$$ wise i will just put better tires on my steelies.
Not too sure how wide the stock rims are...hmmm...anybody know??hypothetically speaking if i went from my stocks to slipstreams and light rubber...how much could my quarter mile decrease by??
Old Nov 6, 2003
Zzyzx's Avatar
Autocross Junky
Its some where between 18 and 20lbs with out rubber.
Old Nov 6, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
DX is like 14x5.5.
I bet you can custom order 14x8s for drag racing. If not, theres probably someone who sells a 14x7. Just search around. Wider is better... it spreads out the tire and your contact patch. And since you don't need to turn hard, the only rubbing issue is with the top of the fender.
Old Nov 6, 2003
Zzyzx's Avatar
Autocross Junky
Cheep Light Drag wheels
Old Nov 6, 2003
02civic's Avatar
thanks guys i really appreciate it. I'll look into those drag wheels too. Would i only buy 2 for the front and then use steelies on the back or do i get special thin wheels?
only prob with these is i'd like to be able to drive to and from the track with them on...so i dont have to mess up my interior carting them around.
Old Nov 6, 2003
Jap-Euro Fusion
You can't drive on the street with true slicks. You'll kill them.
If you get DOT drag slicks they'll last a little longer, but not much. Your best bet is to swap them at the track. You can use the steelies in the back.
2 wheels should fit in the trunk. Just put a blanket over them if it bugs you, but I've tossed 4 wheels in the car a few times, never messed anything up.
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
montanacivic
Sep 7, 2015 08:48 AM
MamaBear2015
Aug 27, 2015 09:29 PM
redcloud
25
Aug 12, 2015 01:23 PM
