Help please ** rotors**
Old Nov 1, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have a 2002 acura EL, (canadian model) it came with 10.25" rotors up front and 9.5" out back. I was looking for new rotors and the only company I could find was KVR, repalcments for the front and back same size as stock.. the 00 SI (SIR) has the same size discs all around, I was wondering if I could use the 00SI application seeing as it is the same size rotors and all. Would this work JUST THE DISCS if they are the same size as mine? I don't see how a different axle would matter to the discs... answer if you have done this or know forsure.. thanks alot for your help
Matt
