Tire Size for 16" Rims?
Old Oct 24, 2003
NytRyder2k2's Avatar
Bay Area
Whats the pros and cons for having 205/40s and 205/45s. What would you run with? Im on Neuspeed Race springs. Any help will be appreciated
Old Oct 24, 2003
dj02's Avatar
i just got my yoko's avs es 100's 205/45/16 and i must say they grip really nice and they ride oh so good very smooth. im puting them to the test this weekned going canyon carveing so we will see how they do. i had falken zeix 512 b4 and i love these tires so much more. i think with 40's the ride is not so smooth but if you do get new tires i would highly recomed the yoko's
Old Oct 25, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
On 16s both tires are on the pretty small side. I thought the point of 16's was to get a little cushion. maybe 205/50s, which is pretty close to stock and should give a little bit of tire. Its a pretty common size, I would assume all the major tires are available.
Old Oct 26, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
The 205/40's would be too small in diameter AND have not enough sidewall to cushion your wheels.
Your profile says you had 205/50-15's, so you could go with the 205/45-16's:
IF you liked the way your 205/50-15's filled your wheel wells, because they are very close in overall diameter (if you think the 15's looked too small, or if you think there is gap to fill, go with 205/50-16's)
IF you can live with the drawbacks that go with the shorter sidewall of the 205/45-16
(it is 4/10" shorter than the 205/50-16, so you get the slightly harsher ride + less protection for your rims)
Did that make sense?
Your choice is between 205/45-16 (essentially a "plus 1" size for the tire your profile says you now have - with the drawbacks listed above) and 205/50-16 (a tire that is close to factory diameter and gives ~4" of sidewall for cushioning your rims)
Old Oct 26, 2003
Bay Area
Yea that makes sense. Thanks for the help guys.
Old Oct 27, 2003
greeot's Avatar
greeot is an unknown quantity at this point
awesome post. i had a couple of questions in mind, and this helped a lot. thanks
Misfit2613
Jul 30, 2015 09:49 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
