Shaking steering wheel and off alignment
Old Sep 18, 2003
Eightball's Avatar
Eightball will become famous soon enoughEightball will become famous soon enough
My steering wheel shakes when I drive at higher speeds and my car pulls to the right really bad. Plus when I hit the brakes my car pulls right really bad. I've had it worked on 4 TIMES!!!!! They have balanced and rotated and aligned my tires and it's still shakes and pulls to the right. Any guesses why? (besides that fact the the people working on my car are retarted)
Old Sep 18, 2003
robbclark1's Avatar
Retired suspension supermod.
the people working on your car don't know what they are doing. take it to a place the has a 4 wheel alignment machine with an electronic balancing machine which pinpoints EXACTLY where they should place the weights and how much is needed. Those ones at firestone and other places suck ***.
unless you really messed something up like your frame, control arm, or tie rod, but I don't think it is that.
Old Sep 18, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Are you using wheel locks?
Old Sep 19, 2003
jr_01civic's Avatar
jr_01civic is an unknown quantity at this point
You might want to check and see if you have hub rings on all four rims.
Old Sep 19, 2003
Eightball's Avatar
I do have wheel locks.
I took it in yesterday and they said a tire was bad and might have a broken belt so they moved it to the back and balanced my tires. I got my car back and drove from Indy to Missouri yesterday and it was driving straight but the steering was shaking even worse. It felt like a wheel was going to fall off. Then it started raining and my car was all over the highway. Worst 6 hours of driving in my life!!!!!
Old Sep 19, 2003
Ronin's Avatar
Try taking the locks off, and using the stock nuts.
I had the same problem and couldn't figure out what the hell was wrong after 5 tire balances at 3 different shops. Finally took off my wheel locks one day for the heck of it, and problem was solved.
Old Sep 21, 2003
whitensimple's Avatar
whitensimple is an unknown quantity at this point
How could it be the wheel lock? They have the exact design as the other lugs just have a different top. Are you tryin to get us all in position for a massive wheel theft . I'd look at brake pads also if it is when your braking. Or go somewhere that has a better balancer.. there's this thing called "road force balancer" Some other things to check for is belt separation inside the tire.. that'll cause alot of bumpiness every time the tire hits the ground. Check also for a bent wheel, I'm sure whoever balanced it would have checked it however.
Old Sep 21, 2003
joescivic02's Avatar
Abercrombie and Fitch
my bros accord does that too..
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
breanna_17
Jul 21, 2015 04:01 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
