Tire Pressure [URGENT]
Old Aug 30, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
I'm on a road trip right now (so far about 6,000km, or about 4,000mi) and I noticed that my tires have lost air. I checked the pressure and it read a shockingly low of 22psi. For the records, I have 17x7 rims, wrapped in 215/45/17 Yokohoma Avid H4 rubbers.
I couldn't find the information for the correct tire pressure, so I put in 26psi. For some reason, the ride quality has improved so much! (it has gotten boucier over last few months) So I'm a lot happier at 26psi than at 22psi, but I was wondering if anybody knew the correct optimal pressure for these tires. Thanks!
Old Aug 30, 2003
slystad810's Avatar
I would reccomend 35 PSI...
The more pressure you put in, the less comfort you have, but you trade that for better handling.
Old Aug 30, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I'd put in 32 psi, b/c after you drive, the psi in your tires will go up. I put in 32 psi, and drive around and then check it again and its at 35 psi. But either way, 32-35 psi is ok. 26 is way too low!
Old Aug 31, 2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
38-40 psi
Old Aug 31, 2003
Zzyzx's Avatar
Autocross Junky
Originally posted by Yakkolio
38-40 psi
Are you trying to blow your tires off their beads? unless your atuocrossing I wouldnt go near those pressures.
Old Sep 1, 2003
WD40's Avatar
WD40 is an unknown quantity at this point
I fill mine to 30 psi when cold.
Old Sep 1, 2003
Travii's Avatar
Travii is an unknown quantity at this point
For the record, the stock air pressure is 30PSI. Most tire places will put them to 32-35PSI just because they are lazy. If you don't care about gas milage I would run them at about 30PSI, if you do you can run them at 35 just make sure you rotate often.
Old Sep 21, 2003
xylamic's Avatar
xylamic is an unknown quantity at this point
I used 40psi on both yokohama paradas and es1000s on 17" wheels for a long time, but after about 40,000 miles, i wanted a softer ride. I'm recommend 32psi, but as far as 40psi, these tires can handle just fine for daily driving.
Old Sep 21, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
so for 205/45/17 tire would the best bet be 35psi??
Old Sep 21, 2003
slystad810's Avatar
Yup, about 32-35 PSI. I set mine at 35.
Old Sep 21, 2003
whitensimple's Avatar
whitensimple is an unknown quantity at this point
I'd recommend 36.. if you keep it below 30 your tires are going to wear on the outsides alot quicker. The max pressure on most of these tires are 44, but I've seen tires like these at 50-70. Someone mentioned the AVS ES100 tires also.. I usually have to have the air pressure at 70-80 to pop the beed into place so I don't think blowing the tire up is that much of a worry.
Old Sep 21, 2003
4bangin's Avatar
ya the paradas have super high pressure ratings. my friend has some in 225/35/18 and he has them at like 43 which i was like holy **** then i read his tire and it says max is like 54 or something.
Old Sep 21, 2003
joescivic02's Avatar
Abercrombie and Fitch
hey is that ur car in your sig man??? nice tire size..
Old Sep 21, 2003
4bangin's Avatar
u talking to me or 01coupe?
Old Sep 22, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
if i lower my car, is that means stiff suspension lost more air?
Old Sep 23, 2003
sKwiD's Avatar
I Queef > You
no, lowering your car just means lowering your car... Air in your tires will be the same...
Old Sep 23, 2003
Mbow's Avatar
32psi is generally the most recommended as the best pressure for street use.
Going hirgher than that and you will most likely see your tires wearing more in the middle than the outside.
30psi is what honda recommends. It's on the door jam sticker like every other car (the recommended pressure for that particular vehicle).
Old Mar 24, 2004
JayFReaZy's Avatar
sorry to bring a old thread back, but I have another question. I have 215/45/17 size tires and isnt having 30 psi too much for that size? If 30 psi is what honda recommends wouldnt that be only for the stock 14" or 15" tires"? Since we have a low profile tire, wouldnt that mean less tire pressure as well? If I run them at 30, there would be no problem at all?
Old Mar 25, 2004
SQCivic's Avatar
SQCivic is an unknown quantity at this point
It depends on the make of the tire. I have 215/35/18 Toyo Proxes that have a 50 psi rating. I run them just under 40.
Old Mar 25, 2004
JayFReaZy's Avatar
how would I be able to find the regular psi for my tire?
Old Mar 25, 2004
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
My tires say that 50 psi is the max to set the beads, but max recommeded is 40psi so I put close to 40 psi in
Old Mar 25, 2004
JayFReaZy's Avatar
would putting 30 psi on 215/45/17 tires be too much?
Old Mar 27, 2004
greeot's Avatar
greeot is an unknown quantity at this point
^^^ not at all man. i've been running the same tire size for about 1.5 yrs on 33-35 psi. 30 might even be on the low side.... recommendation is an extra psi for every inch you add on the stock size....
Old Mar 27, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Um, read the damn tire bro. It says it on there, cold and hot psi.
Old Mar 28, 2004
slystad810's Avatar
As a general rule of thumb, +1 or 2 PSI for every plus size to meet the load carrying requirements. For example, Honda reccomends 30 PSI in a 185-65-15, go up to a 195-60-16, and add 2 PSI. For 17 inch, run 34 PSI, 18 inch 36 PSI, 19 inch 38 PSI.
This is just a general rule of thumb, but it is good to follow.
mjdiaz89
Jun 21, 2016 09:26 PM
Kyles24
Jul 12, 2015 09:15 PM
JUNITO
Jul 9, 2015 08:36 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
