Tires losing air please help
Old Aug 25, 2003
droppin187s's Avatar
droppin187s is on a distinguished road
Question Tires losing air please help
I just recently put rims and tires on my car but on seems to loose pressure. This really worries me and I do not know what to do about it. I filled the tires up at 38 psi each at the gas station a few days ago and i checked and 3 held the air but one tires was down to 28 psi!! does this mean i need a patch or a newtire? Please help me, thanks.
Old Aug 25, 2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
you might have a nail just get it checked at discout tire or something.
Old Aug 25, 2003
alright, yea i guess this is a personal problem not a problem someone could solve over the internet
Old Aug 26, 2003
jjj784's Avatar
jjj784 is an unknown quantity at this point
fix-a-flat will help out in the meantime i hope. =]
Old Aug 26, 2003
Deejai35's Avatar
Deejai35 is an unknown quantity at this point
I had a slow leak similar to this... come to find out, there was a nail on the inner tread of my tire. It sucked having to replace a tire with a lot of tread left on it. Definately take it and have it checked out... most places won't charge you. And its only like $15 to repair it, if its repairable.
Old Aug 26, 2003
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
the bead of the tire might not have set firmly enough. Make sure that you take it somewhere, and have them pull the tire off to make sure it isn't a nail or something easy like that, then also have them use bead sealer around the edges of the tire/rim area to make sure that it seats properly and holds in the air
Old Aug 26, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
NO NO NO!!!!!!
DO NOT put that **** in your tire. Not only do tire shops hate it, it ruins the balance of the tire cuz they can never get it all out.
Your leak can be from a few things...
The tire may not have seated properly (Go back to where they were mounted)
The valve stem is bad... open the cap and see if you can hear air leaking, if you can, you need a new valve stem core. Its a very simple DIY fix. Go to NAPA or something and buy valve stem cores and the tool needed to change them (grand total <$5). Jack the tire up, unscrew the old core, and screw in a new one, then re-inflate the tire.
Or you hit a nail/something sharp. You should be able to see this, find a tire shop that does patches from the inside NOT plugs. Plugs ruin tires.
Old Aug 27, 2003
b18c1boy's Avatar
b18c1boy is an unknown quantity at this point
fix a flat will corrode your wheels too. trust me i have seen it. i work with tires and wheels every day. i work for ntb. fix a flat will eat your wheels.
Old Aug 29, 2003
jjj784's Avatar
wow, i didn't know that. thanks for the tip.
Old Aug 29, 2003
slystad810's Avatar
Yup, I work for Discount Tire. Fixaflat is the worst **** ever made... lol
The worst thing about it is that half the time it doesn't even seal the leak.
Take it up to Discount Tire they will fix it for free if you bought tires there. If not it's $12.
Beware of those "Farmer plugs" also. The ones that they put in from the outside. Those let water into the inside of the tire which corrodes the steel belts and causes a tread seperation. In other words, they fu*k up your tire.
Old Aug 30, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
I couldn't have said it better!
Old Aug 30, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
man just go spend 5 bucks and have it plugd.. wow some people are helpless... and yea fix a flat is the worst invention made... but hey if ur in the middle of no where with no spare.. i guess its worth the new tire.. but NOT a new rim.
Old Sep 1, 2003
WD40's Avatar
WD40 is an unknown quantity at this point
Agreed. I put that **** in my tire once and they couldn't get it to balance for anything. Finally I rememberd I had put that stuff in and they pulled the tire off and dumped it out, then it balanced fine.
I wouldn't only use fix-a-flat in an emergency situation and I'd get it out ASAP afterwards. It's definitely not a long term solution.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Shakzhussain
May 17, 2015 12:03 PM
bo_red
Apr 23, 2015 10:09 PM
deus-ex
Apr 13, 2015 12:29 PM
technosilver
Nov 14, 2001 10:58 AM
